Offset grind 3.75 crank limit #2427127
01/01/18 03:14 PM
01/01/18 03:14 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
I have a new 440 3.75 crank that checked out good on journal size and taper. If I have it offset ground to use a 2.20 rod, what is the most stroke I should expect? Is there any option for an even smaller rod journal size that is still strong enough for a stroked 440?
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427131
01/01/18 03:18 PM
01/01/18 03:18 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You can offset grind to a 3.90 stroke and use your favorite BBC rod. You could go a little more if you went with a sbc journal 2.100". I just sold a set of Manley aluminum rods exactly for that purpose.
[image][/image]
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427134
01/01/18 03:23 PM
01/01/18 03:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
3.90 is the most common way as stated. IMO makes a very good engine package for sure. I did have one done to a 4" stroke as well. Worked fine and that crank is still alive and working as far as I know in the old Duster.
Re: Offset grind 3.75 crank limit [Re: Al_Alguire] #2427187
01/01/18 04:03 PM
01/01/18 04:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
There was an Engine Masters article where Buck Hinkle took an old 361 B and put a B based 3.74 crank offset ground from a 3.375" stroke B with a long 2.00" (327) SB Chevy rod and +.060 400 SBC 4.185" piston in it, so at the extreme with an RB 3.75" crank it looks like you could go easily to 4+ inches by going less than the 2.200 BBC journal, provided you can find a long enough and wide enough rod to work and a piston/pin combination as well.
Whether it's practical do do is another matter, buck actually also took the MAINS down to 2.45" SBC size and make steel bearing cap spacers to cut down on the bearing speed.
WIZE
In Car:
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427245
01/01/18 05:19 PM
01/01/18 05:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The math: maximum offset = old journal - new journal.
Stroke change: offset (- .005" or so for the grinder to spark out unless the crank is new)
2.375" (B/RB) - 2.20" (BBC) = .175" max
3.75 + .170" = 3.92" max
You can have any stroke change between - the offset to + the offset.
[Please note: it's not the offset X 2]
Boffin Emeritus
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427249
01/01/18 05:22 PM
01/01/18 05:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
2.100" SBC rod journals smile
Re: Offset grind 3.75 crank limit [Re: polyspheric] #2427253
01/01/18 05:29 PM
01/01/18 05:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's a nice explanation.
At one point I made a simple Excel spreadsheet that allowed entering stroke, rode length & deck height to calc the piston compression height. It made it easier to figure out if there was any combination of stroke/rod/CH for an already-machined block that could be used with off-the-shelf parts, rather than having to get more expensive custom pistons made. Don't have it any more, but something like it helps figure out "real world" combinations quickly.
Re: Offset grind 3.75 crank limit [Re: Al_Alguire] #2427256
01/01/18 05:32 PM
01/01/18 05:32 PM
BradH Offline
BradH  Offline
I was wondering about that, but I don't know if they're made long enough to work with an RB block the way the OP described it. shruggy
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427266
01/01/18 05:46 PM
01/01/18 05:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We used a GRP aluminum rod..Makes for a world of possibilities smile
Motor didn't make huge power for sure. Ran 9.60's in a 3150lb back half Duster with iron heads. Not sure if I have any pics from the engine build it was a long time ago for sure. The engine was in the car when I purchased it and was assumed it was a 3.9" stroke deal. When I tore it down after making a few passes is when we found the 4" stroke and SBC journal, had Groden rods in it then. I replaced rods and pistons as well as new cam and rebuilt it. Was in this one from way back when...
Re: Offset grind 3.75 crank limit [Re: BradH] #2427268
01/01/18 05:52 PM
01/01/18 05:52 PM
sgcuda Offline
sgcuda  Offline
Like I said, I just sold a set of Manley aluminum rods. 2.100 big end. .990 small end. 6.72 length. They were custom cut at the time, but I'm sure I didn't have the only set.
Re: Offset grind 3.75 crank limit [Re: sgcuda] #2427671
01/02/18 12:14 PM
01/02/18 12:14 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
I don't like the idea of aluminum rods in a street strip car. Looks like 3.9 is what I should expect staying with a 2.2 steel rod.
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427708
01/02/18 01:45 PM
01/02/18 01:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Aluminum can last a long time, if you warm it up first and keep the RPM down.
Triumph 3 cylinder bikes: 70,000 miles.
Boffin Emeritus
Re: Offset grind 3.75 crank limit [Re: BradH] #2427779
01/02/18 03:45 PM
01/02/18 03:45 PM
NH, USA
toddinNH Offline
Egghead
toddinNH  Offline
Egghead
NH, USA
I only work on really odd stuff so everything is custom. Expensive yes, but I only do client's builds. Inline 4 valve stuff is a small market.
At any rate, here is a decent CH calculator:
Compression height calculator 1
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427875
01/02/18 06:22 PM
01/02/18 06:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A calculator? A spreadsheet? How about a hand-crank adding machine circa 1880? This is far, far simpler than calculating chamber volume.
If you're still not sure:
deck height
- rod length
- stroke length ÷ 2
= piston CD
Boffin Emeritus
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2427910
01/02/18 07:04 PM
01/02/18 07:04 PM
gregsdart Offline
gregsdart  Offline
I built a 4 inch x 4.350 440 (475cubes) offset grinding a stock crank to 2.100 using custom 7.10 rods several years ago. The rods were on 396 BME cores. For a street strip application with small port heads the stress on those rods would be very low. I talked to the guy i sold that shortblock to about fifteen years after the sale. He had been racing it , street driving it a lot, nitrous used. It was still running fine.
Re: Offset grind 3.75 crank limit [Re: polyspheric] #2427938
01/02/18 08:08 PM
01/02/18 08:08 PM
BradH Offline
BradH  Offline
deck height
- rod length
- stroke length ÷ 2
= piston CD
Get over yourself. I threw the spreadsheet together for fun so that I could plug in the #s more quickly than repeating the same calculation with only one variable changing.
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2428086
01/03/18 12:47 AM
01/03/18 12:47 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Time for a group hug😃
Re: Offset grind 3.75 crank limit [Re: PorkyPig] #2428116
01/03/18 02:04 AM
01/03/18 02:04 AM
New York
polyspheric Offline
polyspheric  Offline
New York
In the event that this has escaped your notice:
My remark was about the previous posts.
His remark was about me.
Boffin Emeritus
Re: Offset grind 3.75 crank limit [Re: polyspheric] #2428295
01/03/18 02:34 PM
01/03/18 02:34 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
That’s why I stay out of these posts. I’m just a too-pid Millwright that likes to keep things simple. Lol.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Offset grind 3.75 crank limit [Re: polyspheric] #2428306
01/03/18 02:49 PM
01/03/18 02:49 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
the two things most Racers don't want to do
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
