Re: CAL-TRACS AND TUNING.............. [Re: actionange] #2427018
01/01/18 01:08 PM
01/01/18 01:08 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
NICE Plymouth!
Re: CAL-TRACS AND TUNING.............. [Re: Thumperdart] #2427069
01/01/18 02:21 PM
01/01/18 02:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You cannot make blanket statements about how much front end travel a given car needs to work. Yes it is a generalization that more power generally needs less travel. However there are plenty of variables left that don't make that a universal statement. Track condition being one of the biggest, along with how free the suspension is account for any suspension binding, weight bias, power available, tire being used, etc etc...Each car will require a different set up and have its own unique requirements. I would not say a car making 700hp is in the realm of absolutely working with LESS front end travel. IMO as you get to 900+ then you can usually overcome the need for pitch rotation with power and leverage...For instance what works on Shilohs car will likely NOT work for Dom and vice versa. Both A bodies, both have Caltracs and both will require a different set up..
Re: CAL-TRACS AND TUNING.............. [Re: actionange] #2427282
01/01/18 06:11 PM
01/01/18 06:11 PM
okla.
sam64 Offline
sam64  Offline
okla.
Originally Posted By actionange
Originally Posted By Thumperdart
I had Morgans book, loaned it out years ago and havn't seen it since........Speaking of tires, my 1.33 was w/old MT 28x10.5 w's and these soft walls aren't happy from 11 3/4-15 lbs..........
Don’t worry Morgan’s book has nothing on Caltrac tuning...
In my Belvedere I had 5 inch front end travel and QA-1 set on 5.
Rear bottom hole with QA-1 set on 5. Weight in driver seat I’d adjust driver side with width of a nickel gap, passenger side 2 flats preload. 1.39 60ft@ 3750 lbs
Morgans book is about tuning suspensions,it all has to work together.Now he can set his car up like yours and it will be fine.
Re: CAL-TRACS AND TUNING.............. [Re: sam64] #2427290
01/01/18 06:22 PM
01/01/18 06:22 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted By sam64
[quote=actionange][quote=Thumperdart]I had Morgans book, loaned it out years ago and havn't seen it since........Speaking of tires, my 1.33 was w/old MT 28x10.5 w's and these soft walls aren't happy from 11 3/4-15 lbs..........
That is about how I have mine set.Never messed with them,,,,,car was leaving straight and all attention was on the carbs and AFRs.
How does preloading help the 60 ft??,,,,,or does it?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: CAL-TRACS AND TUNING.............. [Re: actionange] #2427363
01/01/18 08:11 PM
01/01/18 08:11 PM
State of confusion
Thumperdart Offline OP
State of confusion
VERY impressive on that tire at that weight........... thumbs
Not sure on the preload w/the Caltracs but I will try a few suggestions........... thumbs
Re: CAL-TRACS AND TUNING.............. [Re: Thumperdart] #2427400
01/01/18 09:14 PM
01/01/18 09:14 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
When I had my 493 it was about 650 HP .
I had the bars set at 1/16th gap .
Re: CAL-TRACS AND TUNING.............. [Re: a493demon] #2427417
01/01/18 09:48 PM
01/01/18 09:48 PM
State of confusion
State of confusion
What shocks and tires..............
