Re: A little science project [[[ updated]]]]
[Re: WHITEDART]
#2428017
01/02/18 10:37 PM
01/02/18 10:37 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Found a before/after of a GT40 lower I fixed for a friend.
[Re: TRENDZ]
#2428040
01/02/18 11:28 PM
01/02/18 11:28 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Thank you for the compliments by the looks of your workmanship you do good work as well
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Al_Alguire]
#2429668
01/05/18 10:58 PM
01/05/18 10:58 PM
WHITEDART
bean town ....Ca
It's hard to believe December 21st..I cut this intake manifold in half. It's been across the country and back.. and now it's back on the motor thank you very much Brett.. your work is amazing and second to none..
[Re: WHITEDART]
#2429876
01/06/18 01:22 PM
01/06/18 01:22 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Anxious to see what happens on the dyno but more importantly how the car accelerates at the track...
[Re: WHITEDART]
#2429889
01/06/18 01:41 PM
01/06/18 01:41 PM
Posts: 4,072 Mo.
racerx
Mo.
[Re: Al_Alguire]
#2429896
01/06/18 01:48 PM
01/06/18 01:48 PM
Thumperdart
State of confusion
Anxious to see what happens on the dyno but more importantly how the car accelerates at the track... I still think the big 2000 cfm carb is over kill and hurting performance at the track maybe not on the dyno but hopefully it gets tuned in better for ya..............
[Re: WHITEDART]
#2429926
01/06/18 02:13 PM
01/06/18 02:13 PM
Al_Alguire
Las Vegas
We have tried alot of carb set ups on the Vette. We started with a 4150!!! Unfortunately only one way to find out what works. Also you can stack spacer to the roof of the dyno and maybe make more power but velocity and efficiency especially down low may kill the cars ET. We have used 2.30, 2.40, 2.45, 2.50. Our issues with the larger carbs has been the deck height of the engine. Possibly with a shorter deck we could take more advantage of the bigger carbs. So far the 2.40 has been the fast one. But we have had probably 8 different booster packages and 4 different metering blocks in it as well. We will likely be trying the 2.45 again this year with the shorter deck and are expecting it to be faster. We will find out soon as the block is about done to shorten the deck height to closer to the other small block we run against. Those seem to be where the really big carbs shine.
I believe Shiloh and the Vette run the same cube engine 417?!? Ultimately the dyno is a tool and you need to be able to interpret what the tool is telling you. Interpreting that data and applying it to the racecar on track are always the hard part.
[Re: Al_Alguire]
#2429959
01/06/18 02:44 PM
01/06/18 02:44 PM
WHITEDART
bean town ....Ca
I believe Shiloh and the Vette run the same cube engine 417?!? Ultimately the dyno is a tool and you need to be able to interpret what the tool is telling you. Interpreting that data and applying it to the racecar on track are always the hard part. 419.9 now
[Re: Al_Alguire]
#2430158
01/06/18 08:32 PM
01/06/18 08:32 PM
WHITEDART
bean town ....Ca
I believe Shiloh and the Vette run the same cube engine 417?!? Ultimately the dyno is a tool and you need to be able to interpret what the tool is telling you. Interpreting that data and applying it to the racecar on track are always the hard part. Al if I could drag you out to the track.. and get you to give me some pointers & advise.. you could probably save me a couple years worth of headaches.. Miss steps and.. heartaches... and broken pieces.. there seems to be some interest growing for the naturally-aspirated Grudge racing on the West Coast.. I just don't know what it would take to get you out there.. especially on the counter of you live on the other side of the country currently
[Re: Al_Alguire]
#2430496
01/07/18 02:17 PM
01/07/18 02:17 PM
Posts: 1,784 PA
W5DART66
PA
Anxious to see what happens on the dyno but more importantly how the car accelerates at the track... Al The intake runner was to long with the spacers I did not shorten the runner of a 420 at all. We just added Plenum Volume to a "420" And positioned carb boosters over each pair of runners better. I think it will accelerate better but.... ever know🙃 Untill you try things. Testing I have done shows this should be good improvement 👍🏻
