Probably a few FE fans on here so I'll post a few pictures. This is a 482 inch FE that I'm building with a buddy for his Galaxie. Original '67 427 side oiler block with a SCAT rotating assembly and the brand new heads from Trick Flow. We got one of the first sets of heads and have them bolted to the short block. Just waiting for some custom intake gaskets from Cometic and the engine will be ready to fire up.
Re: New Trick Flow heads for Ford FE
[Re: AndyF]
#2425635 12/30/1703:42 AM12/30/1703:42 AM
The interesting thing about FE engines is that there are a ton of different intake manifolds available. And the FE intake is super complex compared to the Mopar big block which makes it weird.
Basically the aftermarket has decided to tool up a bunch of really complex low volume intakes for the FE engine while they refuse to build simple intakes for the BB Mopar. Guess they just love the FE for some reason.........
We're using a tunnel wedge intake which is kind of a cool intake but there is nothing like that available for a BB Mopar engine. The tunnel wedge will be topped off with dual throttle bodies from FAST. The ignition is also from FAST and will all be controlled by the EFI system.
[Re: AndyF]
#2425648 12/30/1704:12 AM12/30/1704:12 AM
Engine rebuilder 390 FE from last weekend. Once I get a couple other projects done I plan to add a turbo. Gotta practice tuning this Sniper NA first though.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: AndyF]
#2425702 12/30/1711:30 AM12/30/1711:30 AM
Have a buddy that's a big FE guy. he's got a '70 mustang FE powered, 4 speed, street car. goes 10.20's. on the back window he's got a big sticker that says " Fear begins with F.E."
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: AndyF]
#2425718 12/30/1712:06 PM12/30/1712:06 PM
That is a neat build, especially with the dual EFI throttle bodies. What are you expecting it to make for HP? Is it incredibly expensive to put roller cams in FE's?
Do you foresee any problems with the slightly longer, taller runners on the rear cylinders like that? What's the deal with the center ridge in the floor of the intake port in the cylinder head?
[image][/image]
[Re: Blusmbl]
#2425765 12/30/1701:30 PM12/30/1701:30 PM
I don't think it will make a ton of power, maybe 625 hp and 600 ft-lbs or something in that neighborhood. The cam is a Comp XR292R solid roller so it is decent size but not huge. Should have a bit of a lumpy idle but hopefully is driveable in the Galaxie.
I don't think it is anymore expensive to put a roller in a FE than a Mopar. Just buy the cam and the roller lifters. The Trick Flow heads only come with hyd roller springs for some reason. Trick Flow makes these heads with hyd roller springs and Ti retainers which seems like a silly combination. So we changed springs and kept the Ti retainers.
Factory FE rocker arms are 1.76 ratio so you get a lot of valve lift from fairly modest lobes.
[Re: MR_P_BODY]
#2425768 12/30/1701:32 PM12/30/1701:32 PM
Sweet! Now lets wait and see if Trickflow makes some heads for a Y-Block aswell.:)
As for intakemanifolds, for bb mopars, Edelbrock makes dualplane dual quads manifolds for RB motors and offenhauser makes singleplane dualquad manifolds for the B series and probably for the RB aswell but cant remeber for sure. OFFY is actualy real cool and has a bunch of oddball stuff in their catalog,check them out you might be surprised of what is available,and considering what i see on their instagram from to time it would not surprise me if they could do some oddball stuff that is not in the catalog aswell.
Totaly offtopic,i wish the smallblock mopar had some exhaustmanifolds as nice as those...
[Re: 1Fast340]
#2425877 12/30/1703:58 PM12/30/1703:58 PM
i think that ridge is for pushrod tube clearance. Pushrods go through the intake on FE engines.
[Re: RUNCHARGER]
#2425901 12/30/1704:18 PM12/30/1704:18 PM
Probably the other way around. The FE tunnel wedge intake was available over the counter from Ford back in the 60's. I don't think the Stage V dual carb single plane showed up until 40 years later.
That intake in the picture is NOT a tunnel wedge. My buddy has a set of those and the ports are as big as baseballs with a tube right thru the middle of them on the intake side. The heads are also very large with no tube restrictions. He said they do not really run that well because of the airflow restrictions from the big pushrod tubes. This is still a very nice looking set up.
Old Geezer Racing
[Re: AndyF]
#2425975 12/30/1706:18 PM12/30/1706:18 PM
Tunnel port intake
Old Geezer Racing
[Re: AndyF]
#2425980 12/30/1706:25 PM12/30/1706:25 PM
I grew up working on FE Fords, I still do some BBF engines.Ford FE series engines, are literally among some of the biggest movers right now for some of the manufatures parts...its scary how many are being built right now. Cheap, easy to find, and decent bang for the buck.460 BBF is same, easy to make great power and torque, and parts ARE available.
RIP Monte Smith
[Re: SCATPACK 1]
#2425992 12/30/1707:13 PM12/30/1707:13 PM
The intake we're using is a tunnel wedge. The intake you are talking about is a tunnel port.
