Page 3 of 3 1 2 3
Re: Demon at track [Re: toplescuda] #2430307
01/07/18 01:29 AM
01/07/18 01:29 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
When it gets a little warmer I'll tell you how fast I get it to. My goal is 9.65 since that's what they got. I realize they practiced 5500 passes to figure it out and they had optimum track conditions. It will be very difficult to launch/feather off the line for best et but we all need goals. I can tell you the other day it was 30 degrees and I had 32 psi in the tires for street driving. I eased the pedal down slowly to keep from letting the transmission kick down (if the trans kicks down the 8 speed goes to 6000 rpm/14 psi boost/800 hp). Before I got to the floor I was doing 100 and it started to spin the tires. The power is there. But it's gonna take a good man to get it off the line.
2011 Drag Pak Challenger
Re: Demon at track [Re: Sport440] #2430405
01/07/18 10:32 AM
01/07/18 10:32 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Originally Posted By Sport440
Originally Posted By toplescuda
[quote=Sport
No proof. But claim. Is. The 9.65 wasn't the best pass. Just the best when doing the record thing
The fastest pass was a 9.30 something at 150 mph
When Pritchett made the 9.65 pass the very next pass one of the high ups..at str.. made a 9.66 pass....so the 9.65 pass wasn't a fluke pass that no else can also do
Never saw a vid/comment or hint of a 9.30 pass, Anywhere. You stated No Proof, But Claim.
Personally, don't believe it ever happened. It took every trick in the book they could muster to get a 9.65. I'm sure that was backed up with a 9.66 right after as the track and DA conditions were the same.
My Point is, These cars are advertised as Turn Key, if everybody can put the drag strip package on from out of the trunk and run a Easy 9, or even a 9.65.
Not going to Happen, most will run 10.20,s to 10.40,s Some, will and may get into the 9,s as delivered from the factory.
It is one heck of a car, but its not going to run as the Marketing guys would have you think Turn Key. For the most part, I see disappointment over the web as to how these cars that Have been run down the track are performing, not Nearly up to par as they Thought they would...
Granted, Modified from stock, Even the Hellcats are running into the 8,s, the Demon will as well.
But I will back up, 10,20s or better from a Turn key Factory car, Waaay Impressive. up up
Just because was no proof dont mean it didnt happend. It was actually talked about on the hellcat forum BEFORE dodge released the time
Even told that was passes where it carried the wheels 15 foot on more then one pass
I dont know if it did or didnt....anything is possible
After people learn what the car wants. I think will be quite a few running 9s
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Demon at track [Re: toplescuda] #2430441
01/07/18 12:51 PM
01/07/18 12:51 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
Re: Demon at track [Re: toplescuda] #2430443
01/07/18 12:58 PM
01/07/18 12:58 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Listen to the engine/shifts. Nothing like a Demon. A Demon has an 8 speed. It is shifting all the time.
Re: Demon at track [Re: rickseeman] #2430462
01/07/18 01:29 PM
01/07/18 01:29 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
it would be easy for a engineer with a laptop to experiment with the gears he or she wanted during wot
Re: Demon at track [Re: toplescuda] #2430468
01/07/18 01:37 PM
01/07/18 01:37 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
From what I can tell, that's a drag pack car, not a Demon.
Re: Demon at track [Re: toplescuda] #2430482
01/07/18 01:56 PM
01/07/18 01:56 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
That is a drag pack car. Not a demon
1971 charger
Re: Demon at track [Re: toplescuda] #2430566
01/07/18 04:22 PM
01/07/18 04:22 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I agree, Drag Pack not Demon. I should have a two or three speed in it.
Re: Demon at track [Re: toplescuda] #2430567
01/07/18 04:25 PM
01/07/18 04:25 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I was surprised that Leah seemed to be the tallest of all the Top Fuel points leaders when they lined up on stage at the NHRA year end banquet, I bet she still weights a lot less than most but not all Demon owners. That makes the 9.65 in stock trim even a little harder to reach.
Bill
Re: Demon at track [Re: 340Cuda] #2430890
01/08/18 02:10 AM
01/08/18 02:10 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By 340Cuda
While I was surprised that Leah seemed to be the tallest of all the Top Fuel points leaders when they lined up on state at the NHRA year end banquet, I bet she still weights a lot less than most but not all Demon owners. That makes the 9.65 in stock trim even a little harder to reach.
Bill
Nice Input. beer
Page 3 of 3 1 2 3
