Re: New Trick Flow heads for Ford FE
[Re: CompWedgeEngines]
#2425996
12/30/17 07:16 PM
12/30/17 07:16 PM
Posts: 31,060 Oregon
AndyF
I grew up working on FE Fords, I still do some BBF engines.Ford FE series engines, are literally among some of the biggest movers right now for some of the manufatures parts...its scary how many are being built right now. Cheap, easy to find, and decent bang for the buck.460 BBF is same, easy to make great power and torque, and parts ARE available. The FE is a cool looking engine with the pentroof valve covers and the wild intake and exhaust manifolds. It is a quirky engine with the pushrods in the intake and stuff like that but I guess that adds character. Some of the stuff is similar to a BB Mopar. Shaft rocker arms, front oil pump, skirted block, cross bolted blocks on the race engines, etc.
[Re: Spaceman Spiff]
#2425997
12/30/17 07:19 PM
12/30/17 07:19 PM
AndyF
Do you foresee any problems with the slightly longer, taller runners on the rear cylinders like that? What's the deal with the center ridge in the floor of the intake port in the cylinder head? i think that ridge is for pushrod tube clearance. Pushrods go through the intake on FE engines. The ridge in the intake port is for flow. They call it a floor wing or a vane. It sits in the low velocity part of the port and helps the mixture make the turn into the valve. At least that is the theory. I suppose Trick Flow did a bunch of flow bench development with and without the wing but they didn't post any of that information on their website so I'm just guessing that they found that it helps. I don't think I've seen a wing like that in any Mopar ports but I've seen it before in some Chevy engines.
[Re: AndyF]
#2426024
12/30/17 08:32 PM
12/30/17 08:32 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Jay Brown is now selling these intake adapters for FE Ford engines. They adapt a 351 Cleveland intake to it. So you have more manifold choices, and you can swap intakes or inspect the valley without draining the coolant and disassembling the valve train. They are selling like hotcakes.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: RUNCHARGER]
#2426056
12/30/17 09:54 PM
12/30/17 09:54 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I race with a bunch of FE ford guys when I meet with the UMTR stick guys. Larry's wagon is a cool FE racer Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2426090
12/30/17 10:52 PM
12/30/17 10:52 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
A friend / customer of mine was looking for a replacement 427 side oiler block a few years ago. I was surprised when he showed me what he had found in an old box ! Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: AndyF]
#2426281
12/31/17 01:19 PM
12/31/17 01:19 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Do you foresee any problems with the slightly longer, taller runners on the rear cylinders like that? What's the deal with the center ridge in the floor of the intake port in the cylinder head? i think that ridge is for pushrod tube clearance. Pushrods go through the intake on FE engines. The ridge in the intake port is for flow. They call it a floor wing or a vane. It sits in the low velocity part of the port and helps the mixture make the turn into the valve. At least that is the theory. I suppose Trick Flow did a bunch of flow bench development with and without the wing but they didn't post any of that information on their website so I'm just guessing that they found that it helps. I don't think I've seen a wing like that in any Mopar ports but I've seen it before in some Chevy engines. I noticed a bid difference in flow swirl pattern on the piston with a tilted port floor on my iron heads from the Edl flat port I have .
[Re: AndyF]
#2428855
01/04/18 01:21 PM
01/04/18 01:21 PM
AndyF
Engine is almost together, just trying to round up the correct intake gasket at the moment. Once we have the correct gasket the top end should fall together quickly.
[Re: AndyF]
#2428869
01/04/18 01:46 PM
01/04/18 01:46 PM
Clanton
northern,Ohio,USA
Engine is almost together, just trying to round up the correct intake gasket at the moment. Once we have the correct gasket the top end should fall together quickly. I think I see oil drain holes in the corner of the heads,Is that correct.
[Re: AndyF]
#2428871
01/04/18 01:56 PM
01/04/18 01:56 PM
Posts: 1,505 TN
SCATPACK 1
TN
[/quote]
i think that ridge is for pushrod tube clearance. Pushrods go through the intake on FE engines. [/quote]
That intake in the picture is NOT a tunnel wedge. My buddy has a set of those and the ports are as big as baseballs with a tube right thru the middle of them on the intake side. The heads are also very large with no tube restrictions. He said they do not really run that well because of the airflow restrictions from the big pushrod tubes. This is still a very nice looking set up. [/quote]
The intake we're using is a tunnel wedge. The intake you are talking about is a tunnel port. [/quote]
My bad Andy. You are correct about it being a tunnel wedge. My typo as i was trying to clear up the statement "the push rods do not go thru the intake port" on those heads or intake. I should have said tunnel port intake. Thanks for sharing this post. Sometimes it is fun to see what other brands have available with out going to Yellow Bullet.
Old Geezer Racing
[Re: AndyF]
#2428873
01/04/18 01:59 PM
01/04/18 01:59 PM
Posts: 1,505 TN
SCATPACK 1
TN
I can see how the floor vane would direct airflow and create a swirl effect. Would this improve on the low end power, OR the Mid range or top end?
Old Geezer Racing
[Re: SCATPACK 1]
#2428883
01/04/18 02:32 PM
01/04/18 02:32 PM
AndyF
I can see how the floor vane would direct airflow and create a swirl effect. Would this improve on the low end power, OR the Mid range or top end? That is my guess but I really don't know. I asked Trick Flow for an explanation on the floor wing but they didn't reply to my email. Which is weird since they sent me the heads for testing.
[Re: AndyF]
#2429411
01/05/18 12:54 PM
01/05/18 12:54 PM
Posts: 4,210 New York
polyspheric
New York
Those long exhaust ports are a heat soak, great place for Swain coating.
Boffin Emeritus
[Re: AndyF]
#2429507
01/05/18 04:53 PM
01/05/18 04:53 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
The ridge in the intake port is for flow. They call it a floor wing or a vane. It sits in the low velocity part of the port and helps the mixture make the turn into the valve. At least that is the theory. I suppose Trick Flow did a bunch of flow bench development with and without the wing but they didn't post any of that information on their website so I'm just guessing that they found that it helps. I don't think I've seen a wing like that in any Mopar ports but I've seen it before in some Chevy engines. [/quote] I seem to remember a article in one of the drag magazines years ago about adding dams in the intake manifolds intake ports to aid airflow, I guess it didn't catch on back then I had a hemi motor that had been built by Petty Ent. for a clone NASCAR 1967 Plymouth of Marty Robbins car, it had the big two piece single Dominator flange bathtub NASCAR intake with a bunch of air dams and ridges cut into the floor. That intake had the best fuel distribution as far as the EGT reading(all within 25 F from part throttle loaded at 1300 RPM to WOT) of any motor I've dyno tested Ford had so many variations of the FE race heads it ain't even funny
[Re: AndyF]
#2434394
01/14/18 01:42 PM
01/14/18 01:42 PM
Posts: 4,785 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I admire engines that are not common/mainstream. FE, Desoto Hemi, Nailhead, 409, Wildcat...Polysphere. Not economical to build by any means but many owners are not pinching pennies when paying to have their project built.
Keep old mopars alive.
