Re: 71 e body deck lid torsion spring
[Re: 6PACKB]
#2425278
12/29/17 11:49 AM
12/29/17 11:49 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
the torsion can be adjusted setting it in another hole for more torsion. My Charger ( no spoiler ) got two springs, one attached on each side. Maybe due the bigger lid ?
A friend of mine molded the trunk lid on his 71 Charger like making somehow a ramp to work like a spoiler with bondo, and never took care of the added weight... allways had to use something to keep the trunk lid open untill I told him to increase the torsion giving one extra hole on each side... problem solved
[Re: blewbyu]
#2425316
12/29/17 01:05 PM
12/29/17 01:05 PM
Posts: 427 Waterford MI
6PACKB
Waterford MI
71 Challenger Did only have one spring rod. I think it may have been just a little bit larger but not much. I think it was how it was positioned that made it work. It must have not worked to well as they returned to 2 rods after 71 Thats what I'm seeing as I research this. Doesn't look like the supports that hold the spring have any provision for using two springs on a 71 model & I'm pretty sure the single is a larger diameter which means the plastic guide the deck lid hinge rides on is probably different as well?
[Re: 6PACKB]
#2425357
12/29/17 02:23 PM
12/29/17 02:23 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
71 Challenger Did only have one spring rod. I think it may have been just a little bit larger but not much. I think it was how it was positioned that made it work. It must have not worked to well as they returned to 2 rods after 71 Thats what I'm seeing as I research this. Doesn't look like the supports that hold the spring have any provision for using two springs on a 71 model & I'm pretty sure the single is a larger diameter which means the plastic guide the deck lid hinge rides on is probably different as well? I think the cars that left with one spring are only setup for one spring, at least my 72 is. I cannot upgrade to dual torsion springs. Loading the single bar enough to keep the decklid up [barely] with a spoiler caused the decklid to twist when shut. For now, I removed the spring until I can get to a strut of some sort.
[Re: 6PACKB]
#2425386
12/29/17 03:24 PM
12/29/17 03:24 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
71-4 used a thicker single rod verses the 70 thinner 2 rods. Challenger are longer than Cuda. Hardtop is different than convertible. 70 is different than 71-4. So there are several different E-body rods. Also the 71-4 single rod will hold a wing when adjusted up tighter.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 6PACKB]
#2425399
12/29/17 04:03 PM
12/29/17 04:03 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Looks like 71 ebodies had a single spring or torsion rod to hold up the deck lid. Is it the same diameter as a 70 or 72 to 74 ebody that has a pair rather than a single torsion rod? The vast majority of 71s have the single larger diameter torsion spring. Very late cars went back to the two spring design.
[Re: 6PACKB]
#2425408
12/29/17 04:22 PM
12/29/17 04:22 PM
moparmarks
So 72-4 had 2 rods? Haven't messed with those years much, mainly just 70-1.
[Re: moparmarks]
#2425427
12/29/17 05:20 PM
12/29/17 05:20 PM
Morty426
Sacramento CA
So 72-4 had 2 rods? Haven't messed with those years much, mainly just 70-1. Yes they went back to 2 rods
[Re: moparmarks]
#2425428
12/29/17 05:23 PM
12/29/17 05:23 PM
NachoRT74
Valencia, España
what I'm saying
[Re: Morty426]
#2425431
12/29/17 05:25 PM
12/29/17 05:25 PM
moparmarks
So 72-4 had 2 rods? Haven't messed with those years much, mainly just 70-1. Yes they went back to 2 rods Well alrighty then.
