Re: 67-up Dart. Roll bar with back seat?
[Re: cudadoug]
#2423836
12/26/17 05:23 AM
12/26/17 05:23 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Most companies offer “seat saver” bars with a bend that are designed to pass through the package tray as an added option to their kit. I just bought an Art Morrison bar, but paid the extra to have those bars custom bent to my dimensions so they will follow the roofline and rear glass tightly.
[Re: mopar dave]
#2423879
12/26/17 01:17 PM
12/26/17 01:17 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I believe mine are S&W and they go thru speaker opening in back deck retaining the back seat. Same here. I don't let anyone ride in the back seat though, if something ever went wrong the rear bars are a good way to get a head cracked.
[Re: cudadoug]
#2423898
12/26/17 02:13 PM
12/26/17 02:13 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Here's a picture of the bar in my '68 A-body.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: justinp61]
#2423959
12/26/17 05:15 PM
12/26/17 05:15 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
I believe mine are S&W and they go thru speaker opening in back deck retaining the back seat. Same here. I don't let anyone ride in the back seat though, if something ever went wrong the rear bars are a good way to get a head cracked. Cage getting installed in my 69 dart as we speak is SW with the back bars through package tray. 8 point with swingouts on both sides. My guy doing it likes the SW stuff
[Re: humpty]
#2424083
12/26/17 08:42 PM
12/26/17 08:42 PM
Posts: 4,704 Wichita
GY3
Wichita
Find a good chassis shop near you and have it custom bent!
They knew little tricks and suggested things I hadn't thought of.
Holzman Race Cars did mine.
[Re: humpty]
#2424351
12/27/17 01:19 PM
12/27/17 01:19 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Nice work man! I'm planning install mine next month and probably I will make something like yours.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: cudadoug]
#2424488
12/27/17 04:48 PM
12/27/17 04:48 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
If I knew how to post pics I would post some of mine. Cannot Get Flickr to work. Anyone else know if an app?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: GY3]
#2424702
12/28/17 12:14 AM
12/28/17 12:14 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Holzman Race Cars did mine. I agree, you'll be much happier. I had ChassisFab Performance do mine in Tallmadge Ohio. Mine is just a 6-point street car bar and I wanted it to fit the seat and arm rest and to be easy to get in and out of the car. The rear bars had to go behind my 6x9 speakers.
