Re: Some stage 6 stuff [Re: fast68plymouth] #2424096
12/26/17 09:03 PM
12/26/17 09:03 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
The earliest ones were pretty famous for porosity.
The ones I've worked on of this vintage often have plenty of issues...... But that hasn't been one I've come across...... Yet.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424167
12/26/17 11:34 PM
12/26/17 11:34 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Very nice work. Thanks for the post.
[image][/image]
Re: Some stage 6 stuff [Re: sgcuda] #2424184
12/27/17 12:04 AM
12/27/17 12:04 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I guess I don't understand why these weren't recycled into 1,000 Miller Lite cans long ago due to the other head choices we have now?! realcrazy
'63 Dodge 330
11.19 @ 121 mph
Re: Some stage 6 stuff [Re: fast68plymouth] #2424185
12/27/17 12:07 AM
12/27/17 12:07 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Amazing work
Re: Some stage 6 stuff [Re: fast68plymouth] #2424188
12/27/17 12:10 AM
12/27/17 12:10 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
look great, and looks like it was alot of work.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424202
12/27/17 12:45 AM
12/27/17 12:45 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Nice work!!
Re: Some stage 6 stuff [Re: upnover] #2424208
12/27/17 12:58 AM
12/27/17 12:58 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Remember when those heads first came out and I wanted some. Saw a set up at summit on a motor and was so disappointed on how they looked port wise, especially the exhaust ports. The valve guides were so huge and port clogging.
They were definitely not designed for a bolt on app, lots of work was needed to make them work great as shown.
Re: Some stage 6 stuff [Re: fast68plymouth] #2424245
12/27/17 02:35 AM
12/27/17 02:35 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Winter project Dwayne.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Some stage 6 stuff [Re: fast68plymouth] #2424344
12/27/17 12:59 PM
12/27/17 12:59 PM
an8sec70cuda Offline
Thanks for the post Dwayne! Your work looks awesome as always. I love seeing these posts even if it's something that I will never have to worry with (hopefully).
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Some stage 6 stuff [Re: fast68plymouth] #2424401
12/27/17 03:03 PM
12/27/17 03:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Very informative. I have a friend that runs these type heads. He's running 6.teens in the 1/8 so they can make power. I'm trying to get him to go B1 because he wants to go faster and I don't think he has much left in these heads. His flow about 310 per Muscle Motors.
Re: Some stage 6 stuff [Re: fast68plymouth] #2425240
12/29/17 04:07 AM
12/29/17 04:07 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thanks Dwayne
Re: Some stage 6 stuff [Re: fast68plymouth] #2425245
12/29/17 04:26 AM
12/29/17 04:26 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Thanks Fast, I'd never own a set, but interesting post on them
Re: Some stage 6 stuff [Re: fast68plymouth] #2426244
12/31/17 11:22 AM
12/31/17 11:22 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
Dwayne is the best!! no detail goes missed. He straightened out my old stage 6s years ago.
Re: Some stage 6 stuff [Re: dart9ss] #2426431
12/31/17 04:53 PM
12/31/17 04:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
When I saw the subject of this t read, I didn't know if I should panic or popcorn and watch the story unfold.
If the owner is using the MP Stage VI RB 4150 intake manifold, he needs to look into getting it reworked to really see the benefits of the improved heads. Out of the box, it leaves a LOT to be desired.
Re: Some stage 6 stuff [Re: fast68plymouth] #2426472
12/31/17 05:13 PM
12/31/17 05:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
Brad......refresh my memory.
Doesn’t the stage 6 manifold really have MW sized runners, and is shrunk down where it bolts to the heads?
That’s how I remember it.......but I haven’t looked at one in several years.
If that’s how it really is, and one was looking for the “next step” in improving the flow into the motor........I would think opening it up, and then making the heads MW size to match would make the most sense.
I think you’d probably have to make a step up from the 509 cam to really see much benefit though.
Re: Some stage 6 stuff [Re: fast68plymouth] #2426504
12/31/17 05:40 PM
12/31/17 05:40 PM
BradH Offline
BradH  Offline
Right, MW-sized runner entries squeezed down to even smaller exits than standard ports as cast... and a sh!tty transition from below the carb mounting pad into the roofs of the ports.
The owner -- IMO -- needs to rethink the build while it's still apart to make the combination "happy". But, it ain't my car, nor my $$$.
Re: Some stage 6 stuff [Re: fast68plymouth] #2426625
12/31/17 07:42 PM
12/31/17 07:42 PM
BradH Offline
BradH  Offline
Originally Posted By fast68plymouth
Finished flow numbers:
Lift-------in/ex----ex w-2" tube
.100---71.3/61.5
.200--149.2/115.9
.300--211.2/157.8
.400--267.4/179.3
.500--306.7/193.2---221.1
.550--319.7/199.3---226.8
.600--318.6/205.4---236.2
.650--320.5/209.8---241.9
.700--321.6/213.9---248.3
FWIW, Dwayne's last test on my old hand-ported Stage VIs:
Stage VI test #1 cylinder:
Lift -- Int / Exh (no tube)
.100 --- 69 / 53
.200 -- 143 / 108
.300 -- 213 / 146
.400 -- 262 / 181
.500 -- 293 / 211
.550 -- 305 / 222
.600 -- 307 / 231
.650 -- 307 / 237
.700 -- 307 / 243
And these were good enough for 600+ HP on a pump-gas 440 w/ the right combination of parts. However, the subject heads are going on something quite a bit different, from the sound of things.
