Page 2 of 4 1 2 3 4
Re: Cold air in a WO23 scoop [Re: SCATPACK 1] #2424111
12/26/17 09:56 PM
12/26/17 09:56 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
Tim, here are some shots of the modifications needed to clear the Holly float bowl. You also need to know that the air cleaner element has half the seating room as you are "all up in it" with the Modification. It will still seal, just be careful and go slow.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2424115
12/26/17 10:01 PM
12/26/17 10:01 PM
Tennessee
Tennessee
So now I have a template made from cardboard, (4 hours). Now I will use it to gauge the metal. I have an 8' long 18 gauge piece of steel with a 90 degree bend to the outside for the rubber seal to clip onto. I will use a manual shrinker/stretcher to form the radius at all four corners. Then body work, paint and last but not least, cut a hole in a PERFECT hood!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2424690
12/27/17 11:48 PM
12/27/17 11:48 PM
Tennessee
Tennessee
Well, back to work, not as much time to spend on the air cleaner project, here are a few photo's of the "wall" being created out of metal. Notice the "1" lip at 90 degrees already bent. A manual shrinker, spreader does an amazing job of creating the radius with the lip already on the metal!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2424703
12/28/17 12:19 AM
12/28/17 12:19 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Awesome! Keep those pics coming!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2424921
12/28/17 03:04 PM
12/28/17 03:04 PM
warren, mich.
dwayne welder Offline
warren, mich.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2424968
12/28/17 05:00 PM
12/28/17 05:00 PM
A727Tflite Offline
A727Tflite  Offline
Looks like you have done that kind of work before. Looks too easy - I'm sure it's not.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2424980
12/28/17 05:20 PM
12/28/17 05:20 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ok, why did you trim the lip by where it meets the carb flange? I need to do this mod on mine but I have been hesitant to just cut on a $600 air cleaner base..
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cold air in a WO23 scoop [Re: astjp2] #2425256
12/29/17 08:57 AM
12/29/17 08:57 AM
Tennessee
Tennessee
To transman, thanks fort he compliment, but no I haven't done this before. And no it is NOT easy, it will try your patients.
The notch cut in the rear carb opening is an example, my mistake.
I thought it was hitting there, it was not, now I have to replace that piece. Part of doing something for the first time!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2425327
12/29/17 01:26 PM
12/29/17 01:26 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Are you going to do A-B-A testing at the track to see if there is a difference?
I'd be suprised if your under hood temps are 200* while you're moving...you're still getting airflow. I can't see an outside air supply adding 65hp+ just based on air temps.
Somewhat unrelated...my Coronet was on a string of 10.50 passes one night at QC when the W023 scoop came off in the shutdown. Next pass, no scoop, just a carb and a big hole in the flat hood, car picks up .08 and 1-2 MPH. Only thing I can think is the carb pan sealing to the hood, and the size of the scoop, were creating a pocket of positive pressure and causing a ton of negative areo drag. No more air pan on the carb for me.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2425414
12/29/17 04:42 PM
12/29/17 04:42 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well I have shrinkers/stretchers for 2 different models, that hand one is a lot harder to use than one with a foot pedal. The foot pedal one allows for 2 hands, and if you are on a stool, you don't loose too much balance.
It looks like you are really getting a handle on it.
Do your carbs have vacuum secondaries or are they double pumpers? Keep up the good work. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cold air in a WO23 scoop [Re: astjp2] #2425530
12/29/17 08:55 PM
12/29/17 08:55 PM
Tennessee
Tennessee
A39coronet, that is interesting stuff. It is hard to argue with back to back time slips!
No I'm not going to test the car at the track. If I had wanted a fast et, I would have chosen a car lighter than 4175lb.!
I just hate having something on my car for the looks with out it serving a purpose. I also need to always have a project to work on, especially during this time of year. So, just thought you guys might be interested.
Re: Cold air in a WO23 scoop [Re: astjp2] #2425534
12/29/17 08:57 PM
12/29/17 08:57 PM
Tennessee
Tennessee
astjb2, Your right, I would LOVE a peddle shrinker. I am balancing the long ends on cardboard boxes and trying to work with one hand on the metal!
I have vacume carbs.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2425546
12/29/17 10:03 PM
12/29/17 10:03 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I hear you on that...plus no excuse to rush making things during the winter and you can take your time to make it right.
Looking forward to the finished product.
Re: Cold air in a WO23 scoop [Re: A39Coronet] #2425577
12/30/17 12:09 AM
12/30/17 12:09 AM
Tennessee
Tennessee
Tonight's progress. When I went to bed last night, I had the radius off. Quite a bit. I was frustrated so went to bed. Tonight after work, with a fresh look, I had every thing "right to the world" in about an hour.
Here you can begin to see why I bought the Shaker base from Tommy, I can just trim away what I don't need and have an excellent "floor to attach the "wall" to.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2425596
12/30/17 01:24 AM
12/30/17 01:24 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Leave an edge on the base that is 1/4-3/8, then roll it up, you will get a good lap weld. Even if you only leave the straight sides, it gives you some sort of edge to weld to. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cold air in a WO23 scoop [Re: astjp2] #2425701
12/30/17 11:27 AM
12/30/17 11:27 AM
Tennessee
Tennessee
Tim, That is a good idea, it would also serve as a reference to hold the wall in place while welding. But first, I two more radius to build. The one on drivers side rear will have to clear wiper motor, very little room back there!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2426149
12/31/17 01:27 AM
12/31/17 01:27 AM
Tennessee
Tennessee
Well, with the front done, all that remains is to match the radius's in the rear, and hit the overall length. A cardboard template does the trick!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2426150
12/31/17 01:31 AM
12/31/17 01:31 AM
Tennessee
Tennessee
The last bends are critical, they must meet up EXACTLY.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2426151
12/31/17 01:33 AM
12/31/17 01:33 AM
Tennessee
Tennessee
Here it is with the lid. There is a lot of trimming excess of of the Shaker base, welding, body work and paint, but the hard part is done. Two weeks of evenings and weekends! Another week at the very least!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2426158
12/31/17 01:50 AM
12/31/17 01:50 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
It looks awesome, if you are good with a torch, you may want to try silver brazing. Its low heat and is 60k psi tensile strength. I am not a fan of mig for real precise work.
What are you going to use for a seal to the hood? I have some rubber product that is 3" wide and come is a roll that you could fasten...or look for a P seal
http://www.brownaircraft.com/product-p/t-6400.htm
Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Page 2 of 4 1 2 3 4
