Page 3 of 3 1 2 3
Re: Automatic Trans Holding Fixture [Re: cudaman1969] #3018020
02/23/22 12:35 PM
02/23/22 12:35 PM
AndyF Offline
AndyF  Offline
Here is one of my more "pro" versions. I had this one plated so it wouldn't rust.
Re: Automatic Trans Holding Fixture [Re: AndyF] #3018022
02/23/22 12:38 PM
02/23/22 12:38 PM
AndyF Offline
AndyF  Offline
I also built some tripod dollies so I could move fully built transmissions around the shop.
Re: Automatic Trans Holding Fixture [Re: qwkmopardan] #3018153
02/23/22 04:47 PM
02/23/22 04:47 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Originally Posted by qwkmopardan
Just use a common 2 wheel dolly. Put bellhousing end up and tailshaft on the floorplate. Use a ratchet strap just above the pan surface at back of bell to hold it to the dolly. Done 100+ this way.
Use a wheelbarrow and you don't even need to mess with the ratchet strap
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Automatic Trans Holding Fixture [Re: Bob Stinson] #3018173
02/23/22 05:53 PM
02/23/22 05:53 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I'm not knocking it one bit but the first thing that came into my head was the intro to dueling banjos.
Re: Automatic Trans Holding Fixture [Re: B1MAXX] #3018600
02/24/22 05:43 PM
02/24/22 05:43 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
You're not the first person to say that. It worked though.
71 Duster w/ a 400
Re: Automatic Trans Holding Fixture [Re: Bob Stinson] #3018605
02/24/22 06:02 PM
02/24/22 06:02 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I do them on the workbench
Re: Automatic Trans Holding Fixture [Re: FastmOp] #3018610
02/24/22 06:19 PM
02/24/22 06:19 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Dropping the clutch assy's in with it pointed up is well worth it in my opinion.
Re: Automatic Trans Holding Fixture [Re: MoParFish] #3018724
02/25/22 07:12 AM
02/25/22 07:12 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Same here. So simple.
"I'm not a Gynecologist, but I'll take a look."
Re: Automatic Trans Holding Fixture [Re: POZEST] #3018797
02/25/22 11:32 AM
02/25/22 11:32 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I just use my Blue Point bench mule.
Torqueflites get one leg bolted to the front tab, use a 2 3/4" spacer with a long bolt on the rear tab. If the tabs are gone, I use the bellhousing.
OE Powerglides I use a couple bolts on the pan flange.
Re: Automatic Trans Holding Fixture [Re: CMcAllister] #3019532
02/27/22 08:48 PM
02/27/22 08:48 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Special thanks to B1MAXX, for the extra photos. It enable to me to create one from an engine stand with very little work-$8 worth of the angle iron and I was in business. It works out good as I can drop it onto the middle leg to pre-load the output for checking final clearance. That’s my chief mechanic, at work there with the converter. My dad will turn 80 next birthday, and I still have to fight him to get to the wrenches first.
F37B4050-AE01-4CD5-973B-F25079D14E67.jpeg9215BCAE-2045-413E-98B0-471BA1499529.jpeg4A0A106C-8BC4-4C29-82FC-24645F78B7A1.jpeg
'75 Plymouth Duster
‘65 Plymouth Belvedere
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Automatic Trans Holding Fixture [Re: clovis] #3019592
02/28/22 07:39 AM
02/28/22 07:39 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Very nice. Your very lucky to have a good partner there. up
Re: Automatic Trans Holding Fixture [Re: B1MAXX] #3019655
02/28/22 11:03 AM
02/28/22 11:03 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
my sentiments exactly ! up
beer
Page 3 of 3 1 2 3
