Automatic Trans Holding Fixture
#2423167
12/24/17 04:20 PM
12/24/17 04:20 PM
Posts: 8,127 Tulsa OK
Bad340fish
Tulsa OK
What is everyone using to hold an automatic transmission while working on them? Trans rebuilding is something I haven't done yet and I think I need to start. Something cheap but safe would be ideal. Also any tool suggestions would be great. Thanks for any input.
68 Barracuda Formula S 340
Re: Automatic Trans Holding Fixture
[Re: Bad340fish]
#2423216
12/24/17 06:04 PM
12/24/17 06:04 PM
Posts: 27,243 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
I keep it simple, it's served me for 40+ years.
[Re: qwkmopardan]
#2423289
12/24/17 08:27 PM
12/24/17 08:27 PM
Posts: 6,001 Anoka County, MN
Leigh
Anoka County, MN
Just use a common 2 wheel dolly. Put bellhousing end up and tailshaft on the floorplate. Use a ratchet strap just above the pan surface at back of bell to hold it to the dolly. Done 100+ this way. 👍 Exactly what I do.
[Re: Bad340fish]
#2423294
12/24/17 08:37 PM
12/24/17 08:37 PM
Bad340fish
Tulsa OK
Some great ideas here thank you. I have been meaning to buy a two wheel dolly anyways, I might try that method. Between selling an engine block and working on a dana 60 project I have had several "dang I wish I had a dolly" moments the last few weeks.
[Re: topside]
#2423326
12/24/17 09:38 PM
12/24/17 09:38 PM
dartman366
Mt. Vernon, Ohio
I had a plate water jetted out with the hole patterns of small block and big block bolt patterns and used an old light weight motor stand and converted it to a tranny stand, works great, I can roll/spin it around in any position.
[Re: Bad340fish]
#2423371
12/24/17 11:52 PM
12/24/17 11:52 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
What is everyone using to hold an automatic transmission while working on them? Trans rebuilding is something I haven't done yet and I think I need to start. Something cheap but safe would be ideal. Also any tool suggestions would be great. Thanks for any input. I've never used a fixture. Once the tailshaft housing is on, one block to prop that end up and another to keep it from rolling and that's it. On the bench, on the floor, on the tailgate of the pickup, wherever is handy.
[Re: Bad340fish]
#2423387
12/25/17 12:20 AM
12/25/17 12:20 AM
Posts: 10,179 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#2423417
12/25/17 02:00 AM
12/25/17 02:00 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case. That wont work when ears are removed for the CSR shield.
[Re: qwkmopardan]
#2423515
12/25/17 11:48 AM
12/25/17 11:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I do all of my trans work at my welding bench and I made up a couple of arms that are welded.. I have a 1/2" hole in the bench so it just bolts to the bench.. very simple.. I've done 5 518s on it so far.. plus I have a tool to compress the OD clutch(about 900* pressure.. I have all the stuff needed for doing the 518s)
[Re: gregsdart]
#2423522
12/25/17 11:56 AM
12/25/17 11:56 AM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I use a similar set-up with my engine stand, bur with a C shaped angle iron fixture bolted to the face of the tranny (I'll post a pic when I get home) I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case.
1979 AMC Spirit, NHRA Q/SA
