Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB412DUSTER] #24247
10/05/06 01:18 AM
10/05/06 01:18 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Ryan have you seen where the Moroso calculator is accurate through out the scale or does it have a window of accuracy?
Since this topic is back up I wonder if Ryan (or anyone) would answer this now?
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB412DUSTER] #24248
10/05/06 07:05 AM
10/05/06 07:05 AM
I use desk top dyno 2000 for my personal use and fun. Does any one have it or is it junk. I like it and used it to set up Johnnys motor CARB,STALL,ETC.Just waiting four the flow numbers four his new heads!!
Re: Most Powerfull 59 Degree Small Block Ever? [Re: Diego_Ted] #24249
10/06/06 07:58 PM
10/06/06 07:58 PM
Castle Rock, CO
W
wegner426 Offline
wegner426  Offline
W
Castle Rock, CO
Ryan,
I know this is off topic, but the link to your website goes to somewhere else.....
Re: Most Powerfull 59 Degree Small Block Ever? #24250
10/06/06 10:05 PM
10/06/06 10:05 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Car weighs between 3050-3060 with driver and fuel.
Best of high 5.80's 114 in the 1/8, 9.40's 142 1/4 mile.
Based on the Moroso speed calculator it's making around 670 HP at the flywheel.
Anyhow.... Don't see 5.80 114 MPH 59 degree SB engine combos every day.
The car is HOOKING for sure running 5.80's in the 1/8th with 660 on tap at that weight.
Our car runs 5.80's @ 118 and put 660 HP to the tires on a chassis dyno with a SBF, motor made @ 725HP on an engine dyno. It has been 9.001 @ 150 1/4. We came in @ 2800LBS in our car.
[image][/image]
Nice engine.
150 MPH @ 2800lbs race weight..... Moroso says 722 HP
And yes the moroso #'s are for a fully optimized chassis/trans/gear/tire drag combo.
If you believe that the moroso is rear wheel HP like some believe..... 660 RWHP @ 2800 should only run 9.27 @ 145
I think in your case it seems to be showing much closer to what we also see with our engine dyno #'s it is closer to flywheel HP.
mloboda's 358" W8 motor was in a 2713# race weight tube chassis '69 Barracuda before we put it on dyno. In good air it went 8.82 @ 152.5 MPH @ Mason Dixon. Moroso says 152.5 MPH @ 2700# = 735 HP. I attached his best dyno pull off Riders SF901...... I dunno what to tell people other than for us this dyno seems to correlate very well with the moroso. Same exact motor made 806 HP on Barton's DTS. Read into it what you may....
And yes I know our website is down, and will be back up within 48 hours.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: RyanJ] #24251
08/15/09 10:43 AM
08/15/09 10:43 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB449VALIANT] #24252
08/15/09 12:21 PM
08/15/09 12:21 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
whats 128.3 @ 3850lbs HP wise
Mopar Performance
Re: Most Powerfull 59 Degree Small Block Ever? [Re: moparniac] #24253
08/15/09 07:07 PM
08/15/09 07:07 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
About 630 HP..............decent for a 59º SB
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB449VALIANT] #24254
08/15/09 07:19 PM
08/15/09 07:19 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Wow this is an old post....
I'd put 449Valiant's ICH motor up against anything 59* in a head to head dyno shootout. 770 On Rider's 902, is around 830 on "most" dyno's. There is little bit more in it as well with different carb & few other small changes I think as well. I doubt too many 59* block motors have ever made what that one does. Some of the Early Ritter/Weber Arrington head X block stuff might have been close, but they usually ran sub 400 inchers, that probably did'nt make quite as much. It's definitely one of most powerfull true 59's out there.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: RyanJ] #24255
08/15/09 08:00 PM
08/15/09 08:00 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
what's 132.93 @ 3220 pounds
dC
Re: Most Powerfull 59 Degree Small Block Ever? [Re: dc426] #24256
08/15/09 08:09 PM
08/15/09 08:09 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
dC
~585 HP on Moroso calc.
590 HP on Wallace Calc
The Wallace Racing Calc: http://www.wallaceracing.com/hpcalculatorquarter.php
Is very close to Moroso as well. Lot's of good calcs on the Wallace site, use it all the time.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: RyanJ] #24257
08/15/09 08:23 PM
08/15/09 08:23 PM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
Seem ICH got it rite
Re: Most Powerfull 59 Degree Small Block Ever? [Re: RyanJ] #24258
08/15/09 08:26 PM
08/15/09 08:26 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Also keep in mind..... your motor is making more power than that, generally the car is never fully optomized to use everything the engine has. Your motor would probably make at least 630 on dyno I use, 650+ on most.
I often see cars not running #, that match well to HP #'s. But in real good setup, like a NHRA S/S or stocker etc, they usually use every bit of power.
I did 367" W2 motor for "mloboda" earlier this year, it "only" made 609? HP but ran 9.79 @ 136 @ 3020 weight already in summer air. That is just good working car that gets almost everything out of motor.... it's stick car, with high $ lightweight clutch/pressure plate/flywheel, so power losses are minimal & chassis works extremely well, not alot of wasted motion etc. If you put that motor in typical 3020# bracket car with a 727, 8% slip converter, leaf springs & 10" slick, it would probably run 10.20's @ 131-132.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: RyanJ] #24259
08/15/09 10:29 PM
08/15/09 10:29 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Real dynos are 1320 ft long
Mopar Performance
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24260
08/15/09 10:58 PM
08/15/09 10:58 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
did you not just read my post? Or the other countless topics we've had on this...
yes I did, hence my post. I do NOT read most of the bs that flies around here.
In fact, I usually avoid these type of posts since there are a few on this board that believe anyone claiming more then 620hp is a liar.
FWIW, my old 422ci RIP made 741hp 635tq when first built.
Now it was hurt when I bought it, melted heads and wore out vsprings, and possibly had a cam swap before I got it which could have robbed some of that power. Regardless, it was still one of the fastest smallblocks on this board. 600hp will not push you 150mph in the 1/4, I don't care what calculator you use.
When I used to advertise "worlds fastest w5" most of you thought I was bragging, perhaps I was some. But what I really wanted was for others who had eclipsed my performance level to step up and post their combo's. Only 2 people in 8 months had claimed to go faster, I believe only one was credible. my
my little motor was often overlooked/disrespected yet sits up top on the fastest list.
SB412's Red Duster was faster than yours, I have seen them both run....412 all natural. Non tube chassis Duster in the 8's....
Re: Most Powerfull 59 Degree Small Block Ever? [Re: DaKuda] #24261
08/16/09 05:35 AM
08/16/09 05:35 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
What measure is used for these calculators, the reason i ask is because i've just put my mph through the wallace calc and after i decided to put figures through from a pretty much stock 440 combo i had years ago. The flywheel hp came out at 295, this does not compare with the factory rated 375 and i would guess my old motor put out at least 25 hp more than stock.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Most Powerfull 59 Degree Small Block Ever? [Re: deaks] #24262
08/16/09 08:02 AM
08/16/09 08:02 AM
, PA
sleepyhead416 Offline
, PA
That was alot of reading BUT I enjoyed it !!!! Glad I didn't have to type it all. LOL
Re: Most Powerfull 59 Degree Small Block Ever? [Re: sleepyhead416] #24263
08/16/09 08:17 AM
08/16/09 08:17 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Lots of different calulators.....
Mopar Performance
Re: Most Powerfull 59 Degree Small Block Ever? [Re: moparniac] #24264
08/16/09 09:23 AM
08/16/09 09:23 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
please tell me more of this red duster?
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24265
08/16/09 09:25 AM
08/16/09 09:25 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I'll let him if interested.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: DaKuda] #24266
08/16/09 09:42 AM
08/16/09 09:42 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I've only seen Laverne's car in photo's, but it runs super strong and looks very nice. I think it's pretty light as well.
