Re: motor plate questions
[Re: Quicktree]
#242144
03/04/09 07:26 PM
03/04/09 07:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Clamps.... its a little different Tony, they flex big time and they are right up against the rearend via a coupling ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Quicktree]
#242145
03/04/09 07:28 PM
03/04/09 07:28 PM
I use a set of old school elephant ears with a solid welded passenger side stock mount. The trans mount is poly. This set up is low buck,strong,and solved my external oil line clearance problem. I run 10.90-11.00 @ about 660 hp.
[Re: MR_P_BODY]
#242146
03/04/09 08:26 PM
03/04/09 08:26 PM
Quicktree
ok lets scale down to a super comp dragster, same deal. they are held on the front by 2 aircraft type water hose clamps and they are not held against the rear end. they do have a coupler but it's loose fit. and with all the flexing you say wouldn't that make it worse? my point is the heavy duty front motor plates are not needed imo.
[Re: MR_P_BODY]
#242148
03/04/09 08:40 PM
03/04/09 08:40 PM
Quicktree
If you wheel stand and run a 1/4" plate and come down hard.... it WILL buckle.... as me. I stepped up to a 3/8" plate with limiters
so will your oil pan and a whole bunch of other stuff ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Quicktree]
#242151
03/04/09 09:26 PM
03/04/09 09:26 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Tony, what exactly is your point? i like the heavier plate because of the 1.cutouts 2. they are made by a member here 3. they are sold by a sponsor here 4. i dont have any extra hose clamps to use as motor mounts
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#242152
03/04/09 09:43 PM
03/04/09 09:43 PM
Quicktree
nothing wrong with it, I don't like the triangle cut outs on that one but it's not going to hurt anything. go for it.
[Re: hemi-itis]
#242154
03/04/09 10:52 PM
03/04/09 10:52 PM
Quicktree
I don't care for the triangles.These go with my weld wheels.I bought mine from V & V machine in Wappingers Falls NY.
that looks much better to me, but thats just my opinion.
[Re: nhramark]
#242158
03/05/09 12:50 PM
03/05/09 12:50 PM
sixpackgut
Charleston
Hey I didn't want to horn in, but Andy has not replied. I can make your motor plate and we will "customize" it for you.(holes, triangles, solid, we can even put a pentestar in it if you want)
PM me if you are interested.
can you post pics of some plates? i would like to see some different ones
[Re: sixpackgut]
#242159
03/05/09 10:46 PM
03/05/09 10:46 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Here is a pic of our new 5.7 Hemi 3/8" motorplate. www.aeicnc.comWebsite will be updated soon, click the automotive tab.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#242160
03/05/09 11:04 PM
03/05/09 11:04 PM
nhramark
Wheels up, MO
Here's a pic from the other side that I didn't botch while re-sizing.
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#242161
03/05/09 11:06 PM
03/05/09 11:06 PM
Posts: 5,620 long island NY
Ari440
long island NY
www.aeicnc.com
will you be able to make 1/4 to 3/8 valvecover spacers for bigblock mopars ?
1.39 9.85 - 137 mph
