Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: gremlinsteve] #2421652
12/20/17 11:03 PM
12/20/17 11:03 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Originally Posted By gremlinsteve
Can you tell us why there not good steff
I used to have notes from a discussion I had with Harland Sharp about them and can't find them. But, I remember getting off the phone with them feeling they weren't too confident about them. But my opinion, I'm not a fan of the aluminum rocker body with the considerable amount of offset the rockers have from roller to pushrod. They are spring limited to what they can handle because of it. T & D's use a steel body. After running my T & D's this year, they've been flawless. Consistent lash. Plenty of oil to the springs, cups and rollers. They Can handle a double valve spring without issue.
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: STEFF] #2421918
12/21/17 05:14 PM
12/21/17 05:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Steff.
R U ever going to market your belt drive?
Matt
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: moparmitch] #2421961
12/21/17 06:38 PM
12/21/17 06:38 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Roller tipped rockers aren't really a necessity... lots of good discussion about them over on www.speedtalk.com .
I have a set of T&D's for my small block but I think I'm going to stick with my iron rockers for 2018... simple and effective. Maybe if I stick with that small block deal after next year I'll use the T&D's.
I'm not overly worried about the juice lifters on the Gen 3's, either. No experience with these new engines right now but my plan B for 2018 is building a simple 5.7 for a back-up and see how it works. I need to be at 650 HP or better and it will be on a dirt track deal.... we'll see.
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: MattW] #2422004
12/21/17 08:35 PM
12/21/17 08:35 PM
STEFF Offline
STEFF  Offline
Originally Posted By MattW
Steff.
Matt
Yes. I lost sight of it and am making it a prioriority to get it out there. Thats, if there's interest.
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: STEFF] #2422020
12/21/17 09:22 PM
12/21/17 09:22 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Steff.
Matt
I am!
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: moparmitch] #2422316
12/22/17 02:35 PM
12/22/17 02:35 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I still have all the programs here for that steff
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: STEFF] #2422331
12/22/17 03:38 PM
12/22/17 03:38 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Steff.
Matt
I'm interested
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: Jerry] #2422340
12/22/17 03:59 PM
12/22/17 03:59 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Not to hijack the thread any , but have you thought about main caps for the G3 Hemi ?
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: Medlock51] #2423070
12/24/17 01:32 PM
12/24/17 01:32 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
[quote=Medlock51]Roller tipped rockers aren't really a necessity... lots of good discussion about them over on www.speedtalk.com .
I'm not overly worried about the juice lifters on the Gen 3's, either. No experience with these new engines right now but my plan B for 2018 is building a simple 5.7 for a back-up and see how it works. I need to be at 650 HP or better and it will be on a dirt track deal.... we'll see. [/qu
Good to hear somebody else is going to use a Gen 3 in the dirt world. Plenty of power.
If you like drag racing, support your local track.
Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: moparmitch] #2423092
12/24/17 02:22 PM
12/24/17 02:22 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
yes we are testing main caps and girdle kit now. should be out in the spring.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
