Some old iron
#2420072
12/17/17 11:10 PM
12/17/17 11:10 PM
fast68plymouth
So. Burlington, Vt.
I realize there are probably only about 4 people here that have any interest in this, but it's winter, and a little slow, so it's a small contribution......
It's pretty common for 40+ year old heads to have visited the machine shop before they find their way to me, and I'd say these had been there at least twice before. They weren't really great candidates for HP heads on a stroker build...... But they are T/A heads..... Going on a real T/A car. I don't have any idea if these are the original heads for the car or not.
At one point they had ex seats installed. Unfortunately they used the wrong size insert(too big), and sunk them a tad to boot. They are big enough on the OD that the intake valve actually sits on the ex seat insert where the two valves are close to each other, so when you sink the ex seat, you then have to sink the intake valve as well. Notice the "high flow" step from using the incorrect seat ring. Real nice guide work too.
Re: Some old iron
[Re: fast68plymouth]
#2420079
12/17/17 11:26 PM
12/17/17 11:26 PM
fast68plymouth
So. Burlington, Vt.
What you can't really see all that well in the pic of the ex seat is why they sunk the ex seat ring. It's so they could peen the edge that's left by sinking it, over the top of the seat to help keep it from falling out.
Call me old school, but I prefer to just use the correct amount of press to keep the seats from falling out.
So, the inserts they used were 1.750 OD, .0625" bigger than the "normal" insert, and they went a little deeper than preferred. If you make the cut big enough, and deep enough..... There is water to be found.
Since the seats weren't pounded out, and there wasn't coolant coming out where it shouldn't be, I figured it would be wise to not tamper with what isn't a functional problem.
I'd blend as best I could, and they are what they are.
I did a bowl blend, rolled the short turns, and smoothed out the pinch area....., along with new guides, valve job, surfaced, cut for dual springs and posi seals.
Re: Some old iron
#2420088
12/17/17 11:42 PM
12/17/17 11:42 PM
dartman366
Mt. Vernon, Ohio
looks good concidering the mess you were handed.
Re: Some old iron
#2420093
12/17/17 11:51 PM
12/17/17 11:51 PM
fast68plymouth
So. Burlington, Vt.
I didn't bother to flow them "before", but I did flow them after the rework.
Ootb 2.02 J heads can flow between 195 and 215. In fact, I've seen two heads off the same motor do just that. One head flowed around 195, the other close to 215. I rebuilt a nice set of stock untouched fairly low mileage T/A heads a few years ago and those flowed right about 200 as removed from the motor.
This set is right about 230@.500 lift(numbers are at work). There was some core shift in these heads, so I didn't go after the intake short turns or open the bowls all that much....... Since they're a little pricier to replace than a std J head.
Re: Some old iron
#2420108
12/18/17 12:28 AM
12/18/17 12:28 AM
Posts: 5,160 Texas
dannysbee
Texas
Looking good! It's amazing what passes for machine work for some people. Great job at straightening that mess out.
Getting old just means you were smarter than some and luckier than others.
Re: Some old iron
#2420116
12/18/17 12:53 AM
12/18/17 12:53 AM
fast68plymouth
So. Burlington, Vt.
For comparison, if you use the correct seat insert, there is very little blending required.
Since the transition from the seat into the bowl has more of the correct shape, and there is less material removal needed to get a smooth transition from the seat into the bowl, you get about 10cfm additional flow, with about 1/2 the effort.
Re: Some old iron
[Re: rt66jim]
#2420264
12/18/17 11:45 AM
12/18/17 11:45 AM
Posts: 13,386 Marion, South Carolina [><]
an8sec70cuda
Well Fast you certainly made them look better. I'm sure they will perform much better. Nice work. I wish I'd taken pics of some of the old chevy sb "double hump" or "camel hump" heads I had come in the shop when I did machine work. I'm sure Dwayne has seen a bunch of those too. Most guys think those heads are the best thing since sliced bread, but every set of them has already been gone through and "upgraded" 15 times since they were new. They'd get real upset when I asked them what color they wanted me to paint their new doorstops?
Re: Some old iron
[Re: an8sec70cuda]
#2420289
12/18/17 12:59 PM
12/18/17 12:59 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Well Fast you certainly made them look better. I'm sure they will perform much better. Nice work. I wish I'd taken pics of some of the old chevy sb "double hump" or "camel hump" heads I had come in the shop when I did machine work. I'm sure Dwayne has seen a bunch of those too. Most guys think those heads are the best thing since sliced bread, but every set of them has already been gone through and "upgraded" 15 times since they were new. They'd get real upset when I asked them what color they wanted me to paint their new doorstops? I just picked up a SBC yesterday with the old double hump race heads....owner said it was touted as a " race motor". It did have tall valve covers,Victor JR and Comp roller rockers, we'll see what happens once I get it opened up....lol
RIP Monte Smith
Re: Some old iron
#2420654
12/18/17 10:46 PM
12/18/17 10:46 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
Thanks for posting, cool stuff. If I remember right you did a similar thread on some big block heads you fixed years ago, but you were able to do before and after flow numbers and the difference was drastic. Thanks again for sharing
68 Barracuda Formula S 340
