Re: Less bump steer with '73+ suspension? [Re: autoxcuda] #2479200
04/08/18 01:33 AM
04/08/18 01:33 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
If you take the time to blueprint it, usually by shimming the box and/or ovaling the idler arm holes (weld washers when done), it is amazing how low you can get the bump steer.
I was online with a British-Midlands F1 engineer during some 4-post tests on a B-body a while back. He was amazed to learn that this "near ideal' (his words) suspension geometry was on a stock '60s US sedan!
Incidentally, it is well known that the '73-up A-Body K's has incredibly lousy quality control, as stated, they were all over the map! I could tell you a story...
Rick
Re: Less bump steer with '73+ suspension? [Re: Rick_Ehrenberg] #2479367
04/08/18 01:07 PM
04/08/18 01:07 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Rick
Speaking of suspensions, 3-5 years ago you started an article on suspensions and mods. You talked about the various spindles and control arm availabilities, bump steer etc. You never finished the article after teasing about a sequel. Now that you are gainfully employed again, how about that sequel?
Carl Kessel
Re: Less bump steer with '73+ suspension? [Re: AndyF] #2579419
11/17/18 02:07 AM
11/17/18 02:07 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Can you use a 71 (340, reinforced) A body K frame with the 73+ center link, ball joints etc? Or would it be better to stick with the 73+ K frame?
I just got the 340 K frame and already have the 73+ spool style, so I can use either one. I plan to add the steering box reinforcements to whichever would work best. I have 11/16 tie rods and the 73 spindles & ball joints.
Re: Less bump steer with '73+ suspension? [Re: NV69B7RR] #2579442
11/17/18 03:50 AM
11/17/18 03:50 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes. But you have to use the 67-72 sway bar that does not go through the K-member.
To me the advantage of the 73+ is narrower sway bar to allow high backspace rims and the safety and durability of the spool motor mounts. They do make locking biscuit motor mounts so that negates much of that benefit. If you are only running 4.25” backspace rims with 245 wide or less tires, the backspace deal might not be an issue.
Disadvantage of 73+ is it fits much tighter around the Milodon Road Race oil pan.
