Re: Mild 470 street / strip motor on the dyno
[Re: Hemi Allstate]
#2418230
12/13/17 11:39 PM
12/13/17 11:39 PM
fast68plymouth
So. Burlington, Vt.
The 440 I referenced peaked before 6k, so I don’t think I’d expect more cubes with the same heads/cam combo to peak any higher.
Id say if the 6000 peak only occurred on one or two runs, it could be an anomaly during testing, or some heat soak in the manifold cost the motor some upper rpm power.
It certainly won’t hurt anything to test a few springs if you feel like you “need to know”.
[Re: fast68plymouth]
#2418279
12/14/17 01:07 AM
12/14/17 01:07 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
The 440 I referenced peaked before 6k, so I don’t think I’d expect more cubes with the same heads/cam combo to peak any higher. I agree the bigger engine would probably peak a little sooner. I am glad to hear this. Id say if the 6000 peak only occurred on one or two runs, it could be an anomaly during testing, or some heat soak in the manifold cost the motor some upper rpm power. The AF ratio was more balanced left & Rt. on that pull.Would that indicate a cooler intake ? Also timing was @ 35* . It certainly won’t hurt anything to test a few springs if you feel like you “need to know”. I might check a few, just to see where I am now. Having this information to compare RPM power pk. is what I was hoping for. I think I am good to go. Thanks Dwayne , Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2418422
12/14/17 12:32 PM
12/14/17 12:32 PM
Posts: 13,390 Marion, South Carolina [><]
an8sec70cuda
Nice build! I have to admit, much stronger than I would have expected it to be!
[Re: an8sec70cuda]
#2418553
12/14/17 05:04 PM
12/14/17 05:04 PM
Hemi Allstate
Mt. Eden Ky.
Nice build! I have to admit, much stronger than I would have expected it to be! Chip, it is much stronger than I thought it would be too. Now I am wondering about the rest of the driveline. Especially the trans front drum, but also the tired old 489 cone type suregrip....... Like that old saying, "Be careful what you wish for" ! Thanks ! Mark
