Re: Affordable street strip electric fuel pump [Re: Triggerfish] #2417939
12/13/17 02:19 PM
12/13/17 02:19 PM
tboomer Online work
tboomer  Online Work
Originally Posted By Triggerfish
I hate noisy elec pumps (holley blue), so when a short pushrod took out the cam lobe on my Hemi, I got a Holley HP 150ghp gearrotor pump & it was SUPER quiet. Could barely hear it with the motor idling. They're $237 at Summit. Also run the Mallory gearrotor design 110 gph pump on my sweptlines 383's and they're even quieter. Their 140 gph pump is $287 vs the Holley 150 at $237 so I'd get the Holley.
That Holley is the one I have for a back up pump. wave
Re: Affordable street strip electric fuel pump [Re: Triggerfish] #2417953
12/13/17 02:34 PM
12/13/17 02:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Check out the reviews of the Holley gerotor pumps on Summit before you go that direction. At first I thought it would be the perfect affordable replacement for my Mallory 140, but there are LOTS of down reviews for the Holley gerotor pumps. Based on that info, I have serious concerns about their reliability, despite the improved design over the original Holley pumps.
Re: Affordable street strip electric fuel pump [Re: tboomer] #2417956
12/13/17 02:39 PM
12/13/17 02:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you put on a elec pump make sure you isolate
it well.. and that includes having a little bit
of rubber hose on both sides of the pump.. if
its isolated well you wont hardly hear it run
even with the engine off(dont use a hard durometer
rubber on it)think like its floating
wave
Re: Affordable street strip electric fuel pump [Re: Von] #2418005
12/13/17 04:20 PM
12/13/17 04:20 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I thought the Mallory pumps were rebuildable. Have you considered that option?
Re: Affordable street strip electric fuel pump [Re: Von] #2418066
12/13/17 05:50 PM
12/13/17 05:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Another vote for the Holly blue or black, been around forever. That should speak for itself. I did used the Carter pump on my Duster with 383 and it worked fine too, always 7 psi
Re: Affordable street strip electric fuel pump [Re: Von] #2418334
12/14/17 03:02 AM
12/14/17 03:02 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By Von
Ron,
I used blues and reds "back in the day"...
Had one or two die. But...they were dead headed. I have a return now, so I assume their life should be longer, and probably quieter.
Your right as I agree. Ron
Re: Affordable street strip electric fuel pump [Re: Von] #2418457
12/14/17 01:39 PM
12/14/17 01:39 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Mallory 140
With a Holley 12-803bp
-10 feed
-8 return
Been in use since 2012
Re: Affordable street strip electric fuel pump [Re: srunge55] #2437458
01/19/18 02:05 PM
01/19/18 02:05 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
They are, sort of. Pretty sure my issue is an armature issue.
Mallory used to service them, but since they were bought out by MSD...they no longer will do it.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Affordable street strip electric fuel pump [Re: Von] #2437474
01/19/18 02:28 PM
01/19/18 02:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Anybody used the Big End electric pumps? I see reference as to them actually being made by Holley??
I run the Magnafuel 300 and it rocks and can be driven for a couple of hrs. according to them............. beer
Re: Affordable street strip electric fuel pump [Re: Von] #2437475
01/19/18 02:29 PM
01/19/18 02:29 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
I have a big end black pump, same as holley. Been on since 2006 dead headed to a holley regulator. It is noisy but I did nothing to help that, its mounted to frame rail with no rubber.
Re: Affordable street strip electric fuel pump [Re: Von] #2437591
01/19/18 06:38 PM
01/19/18 06:38 PM
BradH Offline
BradH  Offline
Pi$$er... I planned to send them the one that's on my car while it's been sitting for years. I tried to rebuild the one I had before that, but botched something and was never able to get it to work again. Never liked working on electrical stuff.
