Re: 76 Volare, yes a volare.
[Re: modelmakerinc]
#2436464
01/17/18 06:13 PM
01/17/18 06:13 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
That looks great! Plus excellent engineering and fabrication.. recycling a wrecked Mopar hood, works with the Volare hood lines, and helps with the clearance you need.
Heck,make a mold of that hood and sell fiberglass copies!! LOL Better put a patent on that puppy,LOL That would be Awesome!
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: modelmakerinc]
#2436592
01/17/18 10:11 PM
01/17/18 10:11 PM
Posts: 1,290 Tucson AZ,
MadMopars
Tucson AZ,
I think you're on the right track. I think it looks way better than other hoods I've seen. The only thing I may have done different would be to remove the center pointed section and left it straight just behind the air inlets, similar to a T/A hood I guess. Kind of a hard thing to test though and not certain it would look any better than it already does. Overall, you should be really happy with it. Very nice work. Always nice to see something different. Edit: I think it looks very nice. Please don't take my input as a negative comment. It was just a thought and I hope it didn't come across wrong... -Trent
[Re: modelmakerinc]
#2441421
01/27/18 11:41 AM
01/27/18 11:41 AM
Posts: 8,131 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I can't convince myself that it is going to look good. Any comments?
Hell yeah that's cool. This is one of my old cars, a buddy did this with a damaged hood we acquired
[Re: modelmakerinc]
#2441637
01/27/18 06:10 PM
01/27/18 06:10 PM
Posts: 2,343 west palm beach, florida
modelmakerinc
Ucudant, that is nice, I thought about the Cuda hood but it didn't have enough clearance bulge in the center and the Cuda guys wanted way too much $$ for rust beat up hoods. I just couldn't get past the pointy area that the challenger hood created when I made it follow the factory hood lines. So I cut a couple more times and added a pie piece in the front. It is a Much improved look and I have no issue on moving forward into filler and finish work. This is a kinda hack job, without being to overly concerned with quality work. Lots of filler will surely hide the flubs.
[Re: basketcase]
#2444456
02/01/18 02:51 AM
02/01/18 02:51 AM
Posts: 5,308 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Your'e "revisions" look much better on the hood! Great thread...keep working on it, and keep us posted...good luck!
Plymouth Makes It!
[Re: modelmakerinc]
#2444517
02/01/18 10:43 AM
02/01/18 10:43 AM
modelmakerinc
Yeah, thanks. I am happy with the hood now, once I get it in primer it should make a much better photo to see the lines and proportions.
I took the car to a shop to get the front suspension rebuilt and aligned. I could have swapped parts myself but I still would have sent it for an aligment anyway so I'm killing two birds.
Once I get it back. I will button up the top end of the motor and do the run-in and fill the brake system. It will be drivable in a month or so. Then I will prep for paint. Soon soon soon.
[Re: modelmakerinc]
#2475033
03/31/18 07:52 PM
03/31/18 07:52 PM
modelmakerinc
Work seriously gets in the way of progress on these projects, unfortunately I'm not wealthy like most everyone else, so here is a long overdue update.
I was able to get about four consecutive days to get the hood pretty close, there is a lot of fabrication so there are a dozen or so small areas that need to be massaged and worked but I was able to etch prime and first coat of hi build.
Overall I am quite pleased
[Re: modelmakerinc]
#2475283
04/01/18 12:37 PM
04/01/18 12:37 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Did you make it functional or is it just for looks? As heavy as the Volare hood is I would cast it in fiberglass as i would your custom bumpers. This is an easy way to remove 200 lbs.
Have a great day Iowan
"obsolete is neat"
[Re: modelmakerinc]
#2475346
04/01/18 01:26 PM
04/01/18 01:26 PM
modelmakerinc
It is functional and actually looks almost factory from the bottom.
If there was any type of market that I thought I could make some money I would make fiberglass parts. But to actually make it worth the effort I would have to sell 20 units at about 500 each. I don't think there are that many interested in it.
As for the bumpers, the mounting brackets are removed and heavily modified so very few people would be interested in them. Unless I made brackets as well.
