Re: Affordable street strip electric fuel pump
[Re: Triggerfish]
#2417939
12/13/17 02:19 PM
12/13/17 02:19 PM
Posts: 26,014 United Socialist States of Ame...
tboomer
I hate noisy elec pumps (holley blue), so when a short pushrod took out the cam lobe on my Hemi, I got a Holley HP 150ghp gearrotor pump & it was SUPER quiet. Could barely hear it with the motor idling. They're $237 at Summit. Also run the Mallory gearrotor design 110 gph pump on my sweptlines 383's and they're even quieter. Their 140 gph pump is $287 vs the Holley 150 at $237 so I'd get the Holley. That Holley is the one I have for a back up pump. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: tboomer]
#2417956
12/13/17 02:39 PM
12/13/17 02:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you put on a elec pump make sure you isolate it well.. and that includes having a little bit of rubber hose on both sides of the pump.. if its isolated well you wont hardly hear it run even with the engine off(dont use a hard durometer rubber on it)think like its floating ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Von]
#2418066
12/13/17 05:50 PM
12/13/17 05:50 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Another vote for the Holly blue or black, been around forever. That should speak for itself. I did used the Carter pump on my Duster with 383 and it worked fine too, always 7 psi
[Re: Von]
#2418334
12/14/17 03:02 AM
12/14/17 03:02 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ron,
I used blues and reds "back in the day"...
Had one or two die. But...they were dead headed. I have a return now, so I assume their life should be longer, and probably quieter. Your right as I agree. Ron
[Re: srunge55]
#2437458
01/19/18 02:05 PM
01/19/18 02:05 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I thought the Mallory pumps were rebuildable. Have you considered that option? They are, sort of. Pretty sure my issue is an armature issue. Mallory used to service them, but since they were bought out by MSD...they no longer will do it.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#2437474
01/19/18 02:28 PM
01/19/18 02:28 PM
Thumperdart
State of confusion
Anybody used the Big End electric pumps? I see reference as to them actually being made by Holley??
I run the Magnafuel 300 and it rocks and can be driven for a couple of hrs. according to them............. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Von]
#2437475
01/19/18 02:29 PM
01/19/18 02:29 PM
Posts: 903 S.E. Minnesota
gtsdude
S.E. Minnesota
I have a big end black pump, same as holley. Been on since 2006 dead headed to a holley regulator. It is noisy but I did nothing to help that, its mounted to frame rail with no rubber.
[Re: Von]
#2437591
01/19/18 06:38 PM
01/19/18 06:38 PM
BradH
Mallory used to service them, but since they were bought out by MSD...they no longer will do it. Pi$$er... I planned to send them the one that's on my car while it's been sitting for years. I tried to rebuild the one I had before that, but botched something and was never able to get it to work again. Never liked working on electrical stuff.
