Re: Trick Flow 270 or Edelbrock Victor Max Wedge
[Re: srunge55]
#2416624
12/11/17 01:53 AM
12/11/17 01:53 AM
Posts: 14,545 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Steve, those are the second version.
[Re: srunge55]
#2416745
12/11/17 12:50 PM
12/11/17 12:50 PM
fast68plymouth
So. Burlington, Vt.
Unlike the std port Victors, the MW version doesn't have the grossly undersized bowls.
IMO, The best bang for the buck flow improvement for those in the street/strip combo would be to go after the chambers and unshroud the valves. That, combined with a decent valve job and some bowl work and they'd work okay.
At that level or rework, they likely still wouldn't flow as good as the TF 270's.
Like I said in Brads latest victor post........ It would be a fun test.
[Re: RAMM]
#2416915
12/11/17 06:22 PM
12/11/17 06:22 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I think you need to talk to CCDave--he has all of the facts, I am missing them. J.Rob Loved that, LOL To the OP, 270 all the way in your case.
[Re: fast68plymouth]
#2417281
12/12/17 11:49 AM
12/12/17 11:49 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Steve, those are the second version. Agree, those have the flat pads on the ports, the first versions did not have those. The second version should have much longer heli-coils in the rocker stand bolt holes too, but make sure. For some reason, I had a head with heli-coils in all the holes except one end? They would be OK as long as you don't try running a large solid roller with 700# open spring pressures.
[Re: Sport440]
#2417630
12/12/17 09:29 PM
12/12/17 09:29 PM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
I think you need to talk to CCDave--he has all of the facts, I am missing them. J.Rob Loved that, LOL To the OP, 270 all the way in your case. Looks like I hurt RAMM’s feelings. Sorry.
