Page 2 of 5 1 2 3 4 5
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406960
11/21/17 06:58 PM
11/21/17 06:58 PM
Italy
Raffaplymouth60 Offline OP
Italy
what do you think of aluminium rod on street use some time ??
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406965
11/21/17 07:09 PM
11/21/17 07:09 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Aluminum rods these days are a much better quality than they used to be. Check with manufacturer as far as life expectancy, but I'm sure that they won't need replacing anytime too soon.
[image][/image]
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407040
11/21/17 09:44 PM
11/21/17 09:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I'm guessing that acceleration is the only goal?
Because that pan (and almost any pan not specifically built for it) has very poor roll (lean to one side) and yaw ("fishtail") oil control. All the baffles, pickups, door etc. are designed to control oil motion in pitch ("hobby horse", wheelie) only.
This is the time to decide of you're going to road race it...
Boffin Emeritus
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: polyspheric] #2407151
11/22/17 12:44 AM
11/22/17 12:44 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Test fit everything carefully. The cam to rod clearance could be an issue with a 4.5" stroke and Aluminum rods. Is that a raised cam core block?
WIZE
In Car:
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407203
11/22/17 02:39 AM
11/22/17 02:39 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
4,5 stroke can fit a megablock with some mods.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Streetwize] #2407211
11/22/17 03:22 AM
11/22/17 03:22 AM
Italy
Italy
i will try this tomorrow! this issue also in 4.5 stroke with World block ?? or only in stock block ?? this is 4.5 bore Mopar World Block
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407219
11/22/17 04:43 AM
11/22/17 04:43 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's something to check. 1mm clearance is minimum. Check the cam clearance to rods, cam end play, and don't forget to set the cam end play to .008 or so, give or take a .002 That's thousandths of an Inch.
There is a lot to check on a motor like your building. I have a similar motor. Ask as many questions as you want. These guys all want to help. We ruffle each others feathers but it's mostly in fun. We all drive MoPar!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407230
11/22/17 06:34 AM
11/22/17 06:34 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
With the thick aluminum rods you should check clearance against the camlobes. I am bulding a Hemi with Mopar rods in a Megablock, and 4.625 stroke, and had to slightly grind on the driver side rods (Eagle steel) in most advanced cam postion to make sure a thick lobed roller cam did not interfere. Less problem with a flat tappet I also mocked up. Interference point is on the rods where the threads exit. That is also a stressed part, so I do not know how much you can grind away if needed.....I highly recommend you check this first, to see if the alu rods will fit.
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407232
11/22/17 07:46 AM
11/22/17 07:46 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nothing wrong with aluminum rods on the street. Use a little tighter bearing clearance to allow for expansion and keep it cool. If the motor runs hot on the street, the oil pressure at idle will suffer and you could knock the rod bearings out of it.
Looks like a bunch of good parts. I would run a bigger pan, big motors will hold a bunch of oil in them at higher RPM. I ran a 12 qt pan. Good luck with the project!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407233
11/22/17 07:50 AM
11/22/17 07:50 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
One thing to add, to go along with the tighter rod clearance. Let the motor get up to temp before you drive. It's all about running the motor in the proper temperature range.
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407238
11/22/17 08:18 AM
11/22/17 08:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran BME 426 forgings in my Mega Block with 4.5" stroke, only slight clearancing. Similar to Al's pics above. Former owner ran a 292@.050", I run a 285"@.050" both fit w/o issue.
Doug
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2407244
11/22/17 09:34 AM
11/22/17 09:34 AM
gregsdart Offline
gregsdart  Offline
I had a gasket failure using that green gasket and oil pump filter plate! This was a common problem with that setup. There are only two bolts holding it on the pump and they are on one side. You can buy a one piece plate, or add a third bolt under the filter area. Best thing to do is to buy the one piece cover. Also do what you can to elimenate 90 degree fittings, especially on the intake side of the pump. Use the better 90 degree fittings made with tubing and a gentle curve if at all possible. Also very important to see if any of the fittings screw into anything far enough to restrict oil flow. I found that the one going through the pan into the swinging oil pickup was restricting the flow path on mine. Just shorten it and taper the entrance of the fitting. keep a very close eye on oil pressure . If you have problems with low pressure because of the oil pan you have, you can band aid it with an oil accumulater. I have to run over ten quarts of oil. I use thirteen with the accumulater.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: gregsdart] #2407988
11/23/17 08:09 PM
11/23/17 08:09 PM
Italy
Italy
Thank you very much for this info , i will check everything on oiling
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: dvw] #2407989
11/23/17 08:10 PM
11/23/17 08:10 PM
Italy
Italy
Doug
wow , i will send my cam info Tomorrow !!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: FastmOp] #2407991
11/23/17 08:13 PM
11/23/17 08:13 PM
Italy
Italy
Thank you very much ! , now i have this questions ; in my old 496 i had used Total seal max seal zero gap rings .. no problem for several pass , i this engine i have JE pro seal gap rings , is good ? or is better zero gap rings ?? i will use 300-350 HP nitrous on this engine
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Oyvind Mopar] #2407995
11/23/17 08:16 PM
11/23/17 08:16 PM
Italy
Italy
OK i will check all rod , for now i have checked only cyl 1 rod and look like a good gap from rod to cam lobe , tomorrow i will check all rods .. Thanks !
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Bigcube] #2407996
11/23/17 08:18 PM
11/23/17 08:18 PM
Italy
Italy
ok ! good info .. right temperature ?? 190-200 F maximum ??
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2408030
11/23/17 09:44 PM
11/23/17 09:44 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
160-180ish deg is what I consider normal range. 190+ is too hot. I had over 100 lbs pressure at idle cold, under 20 lbs at idle at 210ish degrees and 30+ lbs of pressure at idle if temp was in the 180ish range. With a big pump the pressure will climb quickly with RPM even when hot, but I never like to see it under 20 lbs when its running.
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2408075
11/24/17 12:05 AM
11/24/17 12:05 AM
I won't run the gapless rings again, ever tsk That was a marketing ploy years ago that didn't work in drag racing or on a halfway serious street car either down twocents
There is power to be found with thinner ring packs with less tension on all three rings like a 1.5,1.5,3.0 MM or .043,.043., 1/16 ring packs, especially with a good vacuum pump up scope
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416487
12/10/17 10:45 PM
12/10/17 10:45 PM
Italy
Italy
