Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416624
12/11/17 01:53 AM
12/11/17 01:53 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Steve, those are the second version.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: fast68plymouth] #2416634
12/11/17 02:34 AM
12/11/17 02:34 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Thanks Dwayne and all for the feedback. I think I will stick with the Trick Flow plan.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: srunge55] #2416745
12/11/17 12:50 PM
12/11/17 12:50 PM
So. Burlington, Vt.
So. Burlington, Vt.
Unlike the std port Victors, the MW version doesn't have the grossly undersized bowls.
IMO, The best bang for the buck flow improvement for those in the street/strip combo would be to go after the chambers and unshroud the valves.
That, combined with a decent valve job and some bowl work and they'd work okay.
At that level or rework, they likely still wouldn't flow as good as the TF 270's.
Like I said in Brads latest victor post........ It would be a fun test.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: RAMM] #2416915
12/11/17 06:22 PM
12/11/17 06:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By RAMM
I think you need to talk to CCDave--he has all of the facts, I am missing them. J.Rob
Loved that, LOL grin
To the OP, 270 all the way in your case. twocents up
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: fast68plymouth] #2417281
12/12/17 11:49 AM
12/12/17 11:49 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Agree, those have the flat pads on the ports, the first versions did not have those. The second version should have much longer heli-coils in the rocker stand bolt holes too, but make sure. For some reason, I had a head with heli-coils in all the holes except one end?
They would be OK as long as you don't try running a large solid roller with 700# open spring pressures.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: Sport440] #2417630
12/12/17 09:29 PM
12/12/17 09:29 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
popcorn
Looks like I hurt RAMM’s feelings. Sorry.
Re: Trick Flow 270 or Edelbrock Victor Max Wedge [Re: RAMM] #2417633
12/12/17 09:33 PM
12/12/17 09:33 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Good stuff RAMMER troll
