Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418810
12/15/17 01:20 AM
12/15/17 01:20 AM
A727Tflite Offline
A727Tflite  Offline
Too cold for me to go to the garage again and I don't want to get snow on my pink slippers but .623 sounds pretty skinny. EDIT - sorry - thought that was your measurement. Mayberry I should have enlarged your image of the mic. 👀
Re: 727 Rear Clutch Upgrade worth it? [Re: A727Tflite] #2418811
12/15/17 01:23 AM
12/15/17 01:23 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Stay warm. laugh2 Those two numbers 623 and 824 are the last 3 numbers in the part numbers. The thickness of both are around .785ish.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418876
12/15/17 04:58 AM
12/15/17 04:58 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I have been upgrading these to late model piston and belvelle spring for years as the early skinny ear spring, a couple of the ears will snap off and piston will over travel and the piston seal comes out of bore and sticks the forward clutches on. The new style stronger spring has to be used with the new style, thicker piston. the 623 part# piston is .830" thick and the 834 part# piston is .780" thick. If you use a old style piston with new style spring you will have the same problem as if the ears broke off an early style spring. Made that mistake, piston over traveled and seal came out of bore and stuck forward clutches on.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418884
12/15/17 05:27 AM
12/15/17 05:27 AM
A727Tflite Offline
A727Tflite  Offline
Only explanation I can come up with is Kokomo machined the late casting to the early spec.
Maybe they ran out of service parts for the early application - stranger things have happened there.
Re: 727 Rear Clutch Upgrade worth it? [Re: A727Tflite] #2418916
12/15/17 11:22 AM
12/15/17 11:22 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I can image. I bought a dirt cheap, new old stock A1 Transmission hp rebuild kit the other day because it has the solid front red band, but it also has a brand new, early bellville in it. Temping to just use it.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2418929
12/15/17 12:04 PM
12/15/17 12:04 PM
A727Tflite Offline
A727Tflite  Offline
If the Belleville is new I wouldn't worry about using it.
The number of cycles they go through, high line pressure, high clutch pack clearance is all additive to their failure.
The piston change was a coordinated change - the rear clutch retainer did too.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2419110
12/15/17 05:49 PM
12/15/17 05:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From the factory TF Service Bulletin, running changes for the '74 model year:
"Neutral to Drive shift quality
A-727 only
The N-D package for the A-727 also required the following changes in the rear clutch. The Belleville spring has a higher load and a reduced cone height and thickness. In the clutch retainer, the Belleville spring seat and cushion ring groove were moved forward. The over-all height of the piston was also increased. The piston and Belleville will not service prior models. The clutch retainer will service prior models."
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2419121
12/15/17 06:24 PM
12/15/17 06:24 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have found a couple sources for the later belleville spring anyone have a source for the later piston?
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 727 Rear Clutch Upgrade worth it? [Re: John_Kunkel] #2419131
12/15/17 06:51 PM
12/15/17 06:51 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
A-727 only
John, I believe you. And I believe my measuring tools as well..
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2419139
12/15/17 07:10 PM
12/15/17 07:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Take both parts back to your supplier shop and
see if you got a bad part.. sounds like both
parts are the same
wave
Re: 727 Rear Clutch Upgrade worth it? [Re: MR_P_BODY] #2419173
12/15/17 08:54 PM
12/15/17 08:54 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
parts are the same
wave
Just gonna mail it back to the ebay seller.They're a trans parts dealer...they can measure it.😂
Re: 727 Rear Clutch Upgrade worth it? [Re: FurryStump] #2419180
12/15/17 09:11 PM
12/15/17 09:11 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Cancelled part#. Used, is your best bet.
Re: 727 Rear Clutch Upgrade worth it? [Re: John_Kunkel] #2419190
12/15/17 09:29 PM
12/15/17 09:29 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
A-727 only
Moving forward with the discussion on this upgrade...per John's post of the service bulletin, Do I need to do somthing to the piston retainer as there appears to be changes made there as well for the '74-up parts. How about the plastic cushion spacer? Is it the same or do I need 74-up specific one?
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2419204
12/15/17 10:03 PM
12/15/17 10:03 PM
A727Tflite Offline
A727Tflite  Offline
We went from metal to plastic on the spacer, they are interchangeable.
The piston retainer is the part with the clutch splines, also called a rear clutch piston support. I don't recall a change to it in 74.
The clutch retainer is what fits around the piston support and that is what had the groove location change made to it in 74.
As the bulletin states it is interchangeable. If you can - you might try to add another snap ring to the one just up from the spacer, it makes the retainer tight to the support if you find yours is sloppy.
As for the retainer - a retainer out of a 46/47/48 will fit the 727.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2419328
12/16/17 01:27 AM
12/16/17 01:27 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
a&a trans offer a spacer that goes between the piston retainer and rear clutch shell. it is a clutch plate that has the material removed and outside turned down to fit into and remove the slop in the unit. i made my own by just using a wizzer tool to turn down outside. works great. a&a charged $10 for one so i just made my own. also qwkmopardan id correct about the piston pushing out of bore. have seen it a couple of times.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2419426
12/16/17 12:29 PM
12/16/17 12:29 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
A&A no longer shows the billet piston or I couldn't find it.
Re: 727 Rear Clutch Upgrade worth it? [Re: FurryStump] #2419654
12/16/17 11:33 PM
12/16/17 11:33 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I talked to the vendor that supplied this oddball piston and he alluded to the fact that there is *two* part numbers on it. He didnt say why, but he is right, there sure is two numbers on it indeed. Not sure if that's normal, but if it's not, then it might have something to do with it not being typical.
Re: 727 Rear Clutch Upgrade worth it? [Re: Hot 340] #2419677
12/17/17 12:31 AM
12/17/17 12:31 AM
A727Tflite Offline
A727Tflite  Offline
That's a 98 part cast date and a late model p/n starting with 52.
I doubt we went back to a thin piston so this piston is a fluke - I would just have him measure pistons until he finds a thick one and send it to you.
I've seen the plant send out parts of the later model dimensions but they had the prior part number still on them. But I can't recall ever seeing two part numbers like his - that's a process violation anywhere within the company.
