Re: Engine Build Philosophy: Port Size vs Application
[Re: Streetwize]
#2416054
12/10/17 03:19 AM
12/10/17 03:19 AM
Posts: 793 Utah
topbrent
Utah
do you have Steve Dulcich's hp/tq graph from his 2003 EM 470/Chapman
... My 517 Chapman design was based a lot on what I learned from Steve's 470 motor and discussions with Dyanne and Dan Costello....and it's the flattest/broadest torque and fastest revving wedge I've ever built...by a mile. No dyno graph, but for those who are interested, here are some of the details of Steve's 470. Lots of clever techniques involved and some smart planning. Peak HP: 752@ 6,500 rpm Peak TQ: 641.9@ 5,500 rpm Avg. HP: 547 Avg. TQ: 598.8 Dulcich 470" 2003 Engine Masters info link a Dulcich 470 Engine Masters info link b .034-inch quench clearance, 12.7:1 Ohio Crankshaft forged steel 3.90-inch stroke TCI Rattler balancer 7.2" diameter Manley connecting rods Ross Pistons Harland Sharp 1.7 rockers Comp MM lobe Solid flat tappet cam 259@.050 single pattern 108 LSA - 102.5 intake centerline Indy 383-13 intake Tapered 4150-4500 HVH spacer adapter Barry Grant King Demon RS carb TTI 2"-2-1/8" step headers Chapman CNC Victor Heads, 285cc INTAKE VALVE EXHAUST VALVE 0.050 -36 cfm - 0.050 -30 cfm 0.100 -73 cfm - 0.100 -60 cfm 0.200 -148 cfm - 0.200 -107 cfm 0.300 -214 cfm - 0.300 -158 cfm 0.400 -270 cfm - 0.400 -210 cfm 0.500 -308 cfm - 0.500 -232 cfm 0.600 -332 cfm - 0.600 -250 cfm 0.700 -350 cfm - 0.700 -265 cfm 0.800 -385 cfm - 0.800 -278 cfm
[Re: topbrent]
#2416124
12/10/17 12:34 PM
12/10/17 12:34 PM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
Thanks Brent,
I see the flow numbers on the intakes are POST Tear-down for his EM 285CC heads, which are lower than his as new bench set in the magazine.
The Chapman 285s from Steves bench (Mopar Muscle May 2004 Issue) were:
.100---77 .200---151 .300---220 .400---283 .500---330 .600---364 .700---375
Dwayne (Fast68Plymouth) flowed my actual set of 285s for Moparts and they were pretty close to this, If I remember right (at the time ) he only used a 10" flowbench so the bigger (>.600 lifts) were maybe a little low compared to being measured on a 28". Here they are from the tech archives:
Lift" I/E
.100 72.5/58.2 .200 153.7/118.6 .300 224.3/178.2 .400 285.2/218.2 .500 329.6/232.8 .600 361.9/245.1 .650 368.1/249.9 .700 364/253.1 .750 364/254.7 .800 364/256.3
At the time we were commenting that although they flowed very close to a well ported set of -1's, they do so with a far smaller CC intake port, so they acheive the flows with much higher velocity (which for a street car equates to responsivenness and torque)
[Re: RAMM]
#2416126
12/10/17 12:41 PM
12/10/17 12:41 PM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
After my 2016 EMC build 469 ci SPEC build using RPM heads I have determined some eye opening results. The SPEC rules that year mandated the use of Edelbrocks RPM heads and no welding or epoxy whatsoever was allowed so this limited us to a stock offset rocker. We were also required to use the stem size and head diameter of the valves that Edelbrock states. This meant 2.14/1.81" and that was it. The cylinder heads were ported hastily and a peak of 298-299 cfm was my first and last result--meaning I didn't agonize at all--they were what they were and that is all. I made a best of 592 ft/lbs @ 3500 rpm ZERO dip and 653 ft/lbs @ 4800 rpm with 680 hp @ 6100-6300 rpm IIRC. This build really makes me question the Victors when used with a standard port opening, I mean if you are required to use a big .650" offset rocker then why the heck would you NOT open the port to gain more CSA?
What this means to me is--On your engine Brad, the Victors are a waste. You could have gotten where you are with regular old RPM,s. I've said it before and I'll say it again--I don't know why Edelbrock would even offer them in a standard port. IMO selecting standard port Victors and not targeting BIG power--800-900HP is a dichotomy. Victors should be used only by masochists and those that are hoping for well into the 800+hp range. J.Rob I would not have used those springs with those rockers on that 2016 EMC build.
[Re: BradH]
#2416131
12/10/17 12:53 PM
12/10/17 12:53 PM
crabman173
crabman173
In general most folks always opt for biggest port--highest flow numbers they can find and afford That is exactly why AFR sells so many sets of ( chevy and ford )heads for about the highest price on the market Biggest valves--highest flow numbers yet many engines that are built with them would be far better drivers and much more fun with smaller port runner volume Folks always want a street car that runs like a dragster They sell fake boobs but not man parts because guys would all have to push a wheel barrow to walk around Head sales people know this simple fact and profit greatly from it
My conclusion is an easy to build cheapo 500CI big block with almost any head will make 570 HP easy as pie and be the most awesome fun most have ever had and often when combined with the right gear. converter/ intake/ carb combo out run many that sport much more HP and if it does not--WHO CARES? Because no matter how much HP you have or how much $$$ you throw at it thirty other guys can wax your behind so ??????????
If you want to go fast attend one of the dragster or funny car deals--pay a couple thou and on day two make a 200 MPH pass--then you are done for least amount possible
[Re: fast68plymouth]
#2416134
12/10/17 12:56 PM
12/10/17 12:56 PM
Posts: 1,051 The Great White North
RAMM
IMO, if you replaced Brads Victor heads with a set of 300cfm RPM heads, milled for equal compression, and left everything else the same, the motor would have made way less power. I don't think it would be much, but even if it was 40hp less than are the Victors really worth the ROI?
Additionally, in "engine contest" trim, there would certainly be some more power available from that combo. More aggressive cam, more rigid rocker arms, ported intake manifold, gas ported pistons, lower tension ring pack, 4500 carb on an HVH SS/adapter...... It easily would have made solidly over 700hp. You bring up some good points here but using my 2016 469 I had 1.5 Comp rockers, no spacer, Holley 950 XP 4150, standard tension rings albeit .043" 3mm Total Seal AP's. Had I been allowed to use a spacer then yes I observed 696HP w 1 1/2" Wilson 4 hole, A 4500 would have undoubtedly yielded even more. Again I would ask just how much power are the Victors worth? 40, 50 hp?
When the RPM heads first came out I built a 448 that was very comparable to Brads 452(same cr, similar cam). I ported the heads to flow in the 300cfm range, and tested them on the motor with a few different intake and carb combos. At that point, the best intake/carb combo i tried was the Weiand TR with 2 x 650 Demon carbs on it. That made around 595tq and not quite 640hp. The next closest single carb test was around 625hp, with a similar drop in tq.
Brads Victor combo made 684hp/605tq with an old school HP950 Holley on it(1.375 venturi), which resulted in the motor using 20cfm less air than when the bigger carbs were being run. Had the bigger carbs been better optimized for the motor, I have to believe some benefit could have been gleaned from that extra 20cfm of air. You know yourself that moving more air but not making power with it is inefficiency. This is telling you that that carb is simply a better fuel mixer. I doubt you could ever turn that extra 20 cfm into power--there no way to trap it without getting into the cam timing events.
With the current crop of std port offerings available, for me the real litmus test would be how much difference in power there would be if you pulled the Victors off Brads motor and plopped a set of ootb TF240's on it. If it made within 10-15hp of the Victors, then that would be a good argument against the viability of the std port version of those heads, at least at that power level. It would be a fun test. It would be a cool test and I'm glad you brought up the TF240's. To me there are nothing more than a fully CNC'd RPM with a slightly nicer chamber. I will have an opportunity to work with them soon. Again--I will reiterate, The TF's cannot be any better than an RPM with the stock valve placement and stock rocker offset.
The nuts and bolts of this particular test is that Brad replaced his ported std port Stage 6's and flat tappet cam with the std port Victors and a roller cam and picked up 20ft/lbs and 60hp. I agree but this can easily be attributed to the roller cam swap. I have seen a 50+ gain with my own eyes, same engine/ same dyno 2 days. Also the Stage 6's could have easily been inferior to Victors that you and Brad ported with the knowledge you have gained over the years.
There are a few things I don't really care for in how the Victors are made, but I'd say the biggest "problem" with the std port version for me is the they are cast with the bowls .300 smaller in diameter than they should be. If they had the bowls sized correctly to begin with(sort of like the original version was), then I would feel better about recommending them for the hot street applications where a high flowing std port head can work. Totally with you on this
As they are now though, they're too labor intensive to be cost effective. Nailed it again
Dwayne I think you and I are on the same page almost all of the time, however I don't think you realize just how underperforming the Victors really are. I don't want to de-rail this thread further with more of their shortcomings (install height, etc....) In short I view the RPM's especially the 75cc version, and TF 240 as the same in power potential. The only difference is the TF's come fully CNC'd. If Edelbrock was smart they would offer their 75cc version fully CNC'c with a GOOD design at the same price point as TF and with their marketing and distribution TF probably would not sell too many. Edelbrock could then market their NOW JUNK Victor line with revised valve locations and angles with only a large port version CNC'd for serious efforts and probably demolish Indy's sales. Sorry Brad, not meaning to derail your thread, the question you posed is a very viable one. A large port in this style of head CAN be crutched with headers, aggressive cam, increased static comp, wrong timing curve, etc..... However when these are missed a giant hole in the power curve often shows up. To sum up: How much more power are the standard port Victors worth over another standard port RPM or TF240? 100hp? nope, 75hp? nope, 50hp? probably not even. ROI @ less than 50hp? Not there for me. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: ccdave]
#2416135
12/10/17 12:57 PM
12/10/17 12:57 PM
Streetwize
Weddington, N.C.
I remember several years ago talking to David Vizard (who lives here in Charlotte) and one thing we both agree on is that Velocity AND Flow are critical to maximizing torque and horsepower, particularly when you consider the slight 'supercharging' or "packing' force that occurs when the intake valve is still open while the piston is coming back up the cylinder after passing BDC. If you still fill the hole as the swept volume is Decreasing...well that my friends is where the magic really happens in terms of high RPM power output. Too small or too low a velocity ports can't achieve this.
To me the ultimate street/strip BBW head might be the Chapman MW ports combined with the TF chamber and plug placement.
And of course "real world" torque is also as much dependent on intake flow as it is the port itself, To me looking at just the port is kinda moot, you have to consider the whole intake tract from the plenum to the valve, again too big is a low/mid torque/response killer, too small is a high RPM HP killer (choke point). But the intake alone has a huge impact on how a motor is going to hit on the dyno or on the street. The intake has to outflow the port or really the flowbench numbers for the port itself are kinda moot. And lets not even go into how the fuel mass in suspension passes through the port. at 12.5 A/F ratio on a 360 cfm port flow you are flowing roughly (air and fuel obviously have different flow cooefficients) a rate of 28.8 CFM of solid fuel (which displaces/subtracts from the same volume of bench Air flow). To me port flow in a poppet valve engine needs to be viewed as a Window (opening and shutting over a fixed time) which is the average sum/mean flow from all the effective lift points....peak flow is only one point of measure.
Sorry guys...my second cup of coffe was kicking in, don't mean to ramble!
[Re: AndyF]
#2416182
12/10/17 02:21 PM
12/10/17 02:21 PM
Streetwize
Weddington, N.C.
Sorry guys, I was just going by the thread title, I didn't think the discussion was limited to the merits of the Victor, or TF, or Chapmans or whatever...I didn't think anything I was saying or bringing up for consideration would be considered going "off topic"...was I??? Finding the neal ideal balance of flow (for power) and Velocity (for torque and drivability...at least in a dual purpose street/strip application) for a given displacement and weight/gearing....well that should always be the goal...right? for Drag racing it gets at least a bit simpler. BTW, Dom's 470 is definately one of the most impressive Eddy RPM combos I've ever seen or heard about, and he's probably getting about as much out of a set of them as there is to have for sure. Actually I was thinking (and judging from the caliber of respected participants) that this was one of the more interesting threads in the past several months.
[Re: BradH]
#2416238
12/10/17 03:31 PM
12/10/17 03:31 PM
Posts: 14,494 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Jesse, I guess we look at the Victors through different eyes. It seems like unless you take them “to the max”, and bolt them onto a similar type of short block, to get every last possible hp out of them, then they aren’t worth using. I see them differently. Again, “if” they had the bowls sized correctly(or using the Pro Comp head)it wouldn’t take any more time for me to port them into the 340cfm range than it would to port an RPM to 300. They aren’t that much more money, you get away from the valley pan gasket, and the chambers are better. If you bought TF240’s and used the recommended HS rockers for the TF heads, or something like T&D’s......then the cost difference of the rockers is diminished considerably. Like I said previously, the big hurdle in using them for me is the way the bowls are cast. One thing I do like about them is they are a true std port head. Not a MW head with a reduced port opening at the flange. If, in your words, flow is velocity......then at 350cfm from a true std port head.......they should be pretty good. IMO, if they made 30hp more than a set of CNC RPM heads on the same motor, same cam, same compression.......I’d be fine with that. I don’t feel like I need to make 800hp out of them to have them be worthwhile. With regards to Brads combo, there is no way the two cams used in his motor would be 50hp apart......with either set of heads. Maybe 1/2 that. As for whether or not his stage 6’s could have been improved today......that wasn’t really part of your original argument. You said your 298-299cfm RPM heads would have made the same power as the Victors. If that’s the case, then the Stage 6’s would also be just as good, since they flowed a little more than 300, and have a better chamber(although those heads required way more work to be made usable than the Victors). Also, at 350cfm @.700 Victors have a better discharge coefficient than the RPM’s at 300, or the TF’s at 325(what they flow on my bench). A 251cc MCH CNC ported RPM flows 315@.700 on my bench. If the flow doesn’t matter, and the c/d doesn’t make any difference........we might as well stop testing heads, since the numbers must not have any bearing on power output. Until someone does “the test”, it’s all just speculation. It’s easy.......don’t like ‘em? Don’t use ‘em.........plenty of other choices. As for the carbs.......couldn’t disagree more. I tried my HP950 on his motor as a point of reference to gauge how well the other carbs were doing their job. It’s by no means my best carb, yet was basically as good as the others we tried. I doubt you could ever turn that extra 20 cfm into power--there no way to trap it without getting into the cam timing events. You totally lost me here. By that logic I guess I could have put a 650 on it and made the same power with even less flow through the motor. I’m confident that had I run the motor with my ported annular 850(which flows about 40cfm more than the HP950) it would have made 8-10 more HP........and picked up most of the lost 20cfm.
[Re: Streetwize]
#2416289
12/10/17 04:34 PM
12/10/17 04:34 PM
RAMM
Actually I was thinking (and judging from the caliber of respected participants) that this was one of the more interesting threads in the past several months. I feel the same way and because I have firsthand experience with this build numerous times I was sharing my thoughts on the whys and hows. Nothing more, nothing less. J.rob
#2416301
12/10/17 04:52 PM
12/10/17 04:52 PM
RAMM
Jesse, I guess we look at the Victors through different eyes. It seems like unless you take them “to the max”, and bolt them onto a similar type of short block, to get every last possible hp out of them, then they aren’t worth using. AgreedI see them differently. Again, “if” they had the bowls sized correctly(or using the Pro Comp head)it wouldn’t take any more time for me to port them into the 340cfm range than it would to port an RPM to 300. But they aren't sized correctly so its another check mark in the Con column.They aren’t that much more money, you get away from the valley pan gasket, and the chambers are better. Chambers are no better. They still make best power @ 35-36 total timing. What makes you say this?If you bought TF240’s and used the recommended HS rockers for the TF heads, or something like T&D’s......then the cost difference of the rockers is diminished considerably. Like I said previously, the big hurdle in using them for me is the way the bowls are cast. One thing I do like about them is they are a true std port head. Not a MW head with a reduced port opening at the flange. If, in your words, flow is velocity......then at 350cfm from a true std port head.......they should be pretty good. IMO, if they made 30hp more than a set of CNC RPM heads on the same motor, same cam, same compression.......I’d be fine with that. I don’t feel like I need to make 800hp out of them to have them be worthwhile. If I can make 700hp from a far cheaper RPM casting then why would I expect the same power from a "better" cyl head?With regards to Brads combo, there is no way the two cams used in his motor would be 50hp apart......with either set of heads. Maybe 1/2 that. As for whether or not his stage 6’s could have been improved today......that wasn’t really part of your original argument. You said your 298-299cfm RPM heads would have made the same power as the Victors. I'm saying they couldIf that’s the case, then the Stage 6’s would also be just as good, since they flowed a little more than 300, and have a better chamber(although those heads required way more work to be made usable than the Victors). I have no input on the previous Stage 6's. What I was implying is that you would no doubt improve them if you were to use them again.Also, at 350cfm @.700 Victors have a better discharge coefficient than the RPM’s at 300, or the TF’s at 325(what they flow on my bench). A 251cc MCH CNC ported RPM flows 315@.700 on my bench. If the flow doesn’t matter, and the c/d doesn’t make any difference........we might as well stop testing heads, since the numbers must not have any bearing on power output. Never said anything of the sort.Until someone does “the test”, it’s all just speculation. It’s easy.......don’t like ‘em? Don’t use ‘em.........plenty of other choices. I won'tAs for the carbs.......couldn’t disagree more. I tried my HP950 on his motor as a point of reference to gauge how well the other carbs were doing their job. It’s by no means my best carb, yet was basically as good as the others we tried. I doubt you could ever turn that extra 20 cfm into power--there no way to trap it without getting into the cam timing events. You totally lost me here. By that logic I guess I could have put a 650 on it and made the same power with even less flow through the motor. You're putting words in my mouth and jumping to conclusions. I test a lot of DIRT 358's that mandate a 650 and everytime we try a larger carb it doesn't hardly ever yield more power--maybe 5 hp more with a big jump in CFM through the hat-these are on 570-580hp engines too. I look at manifold vacuum closely and see best results when 1.5-1.7 " hg is observed. I’m confident that had I run the motor with my ported annular 850(which flows about 40cfm more than the HP950) it would have made 8-10 more HP........and picked up most of the lost 20cfm. Dry flow on the bench doesn't mean a whole lot but perhaps you are right-wish you would have tried it. J.Rob
[Re: BradH]
#2416309
12/10/17 05:01 PM
12/10/17 05:01 PM
fast68plymouth
So. Burlington, Vt.
I’ll only add this..... Brads motor made the most HP of any std port motor I’ve tested. It wasn’t the biggest, didn’t have the biggest cam, or the most compression.......but it did have the highest flowing heads. I’m confident that had I run the motor with my ported annular 850(which flows about 40cfm more than the HP950) it would have made 8-10 more HP........and picked up most of the lost 20cfm. Dry flow on the bench doesn't mean a whole lot but perhaps you are right-wish you would have tried it. That’s exactly what happened when we did it with the stage 6 heads. If I can make 700hp from a far cheaper RPM casting then why would I expect the same power from a "better" cyl head?
You mean the $54 per head? If the flow doesn’t matter, and the c/d doesn’t make any difference........we might as well stop testing heads, since the numbers must not have any bearing on power output. Never said anything of the sort.
Well......IMO, you did indirectly. Your position is that your 299cfm heads that flow 50cfm less than the ported Victors, that also have a lower c/d.......would make the same power on Brads short block. That certainly seems like you’re saying to disregard the c/d and fairly substantial flow differential. Maybe it’s my lack of knowledge of the platform for the low expectations of what I was looking for out of the Victor heads.........but they performed as I thought they would on Brads motor. The best stock stroke RPM headed motor I’ve tested(which as it turns out had 300cfm intake ports) was an RB 451 with a tall filled block, Ross dome pistons(13:1cr), aluminum rods, ported Victor intake with a blended HVH SS 4500/4150 spacer/adapter, Pro Systems 1050 Dominator, 272@.050 flat tappet cam, .650 lift with 1.6 rockers, big box style pan.......and that motor made 652hp and about 570tq........and I was pretty happy with that too.
[Re: 451Mopar]
#2416530
12/10/17 11:55 PM
12/10/17 11:55 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My motor is a old Engine Masters motor and I have never used anything but 93 octane pump gas in it. Has run fine for 5 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Streetwize]
#2416755
12/11/17 02:02 PM
12/11/17 02:02 PM
BradH
Sorry guys, I was just going by the thread title, I didn't think the discussion was limited to the merits of the Victor, or TF, or Chapmans or whatever...I didn't think anything I was saying or bringing up for consideration would be considered going "off topic"...was I??? No problem. It was NOT intended to be a brand-specific promo or bash thread, as I did state originally. That it took on that sort of flavor... well, it is what it is. Hey, "Let it roll..." Actually I was thinking (and judging from the caliber of respected participants) that this was one of the more interesting threads in the past several months. Thanks. I was really hoping it would generate some interest and add some value, given what I believe this forum is intended primarily to be.
[Re: BradH]
#2416819
12/11/17 04:31 PM
12/11/17 04:31 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
It seems to me that a too big of port thing is not as important as it seems at first glance, a stone stock 392 CID GEN III hemi runs great at 2000 RPM with huge ports, next time you drive one with a 6spd try lugging it at low RPM, seems to run just fine, as a matter of fact the eagle 5.7 has almost as big of ports with even less displacement and make plenty of TQ down low and has great throttle response once the DBW crap is tuned right.
Wet flow dynamics is more than just high velocity. These modern engines work so well because the engineers work on improving all aspects like flow, swirl, velocity, cam timing, runner length, ex flow, chamber shape, spark plug placement (find a way to get the plug in the richest mixture part of the chamber), cool intake air (hint... the manifold is a lot more important in keeping the charge cool before entering the chamber than the part the air filter is hiding in).
Bottom line is you can still make big TQ with big efficent ports but you can not make big HP with little ports no matter how "efficent" they are. I got a set of modern cylinder head CNC 302 casting heads and velocity is incredible but even jeff said he had a hard time making 500 hp with em but TQ was great. You just got to find a balance that works for you.
[Re: RAMM]
#2416869
12/11/17 05:56 PM
12/11/17 05:56 PM
Posts: 5,161 CT
GTX MATT
CT
Victors should be used only by masochists Do you follow Brad's posts on here?
