Re: VVT cam journal size . [Re: aus370] #2414590
12/07/17 09:48 AM
12/07/17 09:48 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Big thanks ric3xrt , steff for clearing this up .
I carefully read through a few times - Convinced me , there's possable work arounds , but just not worth it .
Re: VVT cam journal size . [Re: STEFF] #2414591
12/07/17 09:53 AM
12/07/17 09:53 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Originally Posted By STEFF
It's totally different between VVT and non-VVT, like shown above. The best way to handle it is to pony up and spend the money on a custom cam core....$1000 ball park. I made an adapter like shown above from Nutter Racing and it's hanging on my wall. Do not like it at all, just hanging off the front. I looked at making an adapter that would include the whole journal instead of just the front only but the wall thickness of the adapter would be too thin in that it would probably crack when being heat treated or being pressed on to the cam.
Again, the best way to remedy this if you are going to use a VVT block and not use the VVT features, is to have a custom core made. That's what I did.
Unfortunately, the current cores available for the VVT blocks are only capable of handling cam specs that are compatible for use with the VVT and computer features.
Who does these custom vvt cam cores.
Re: VVT cam journal size . [Re: aus370] #2414592
12/07/17 09:57 AM
12/07/17 09:57 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
LSM
Re: VVT cam journal size . [Re: aus370] #2414728
12/07/17 03:21 PM
12/07/17 03:21 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
So, is there any way to use a VVT cam in VVT block, but lock out the function? Just curious...
Re: VVT cam journal size . [Re: cudadoug] #2414732
12/07/17 03:23 PM
12/07/17 03:23 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Yes, Comp has a VVT Lock kit.
Re: VVT cam journal size . [Re: aus370] #2414749
12/07/17 03:55 PM
12/07/17 03:55 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Would it be possible (or has anyone tried) to manually control the solenoid so you can set your ICL on the fly? Advance it for bottom end and retard it for top end? (Or whatever works best for your combo)
Re: VVT cam journal size . [Re: aus370] #2414844
12/07/17 06:47 PM
12/07/17 06:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
With a large cam piston to valve clearance might be a problem. I believe the Megasquirt 3 goldbox platform supports VVT for the G3. I know megasquirt is capable of VVT control on lots of other cars.
68 Barracuda Formula S 340
