tunnel Ram small Block
#241343
03/02/09 09:00 PM
03/02/09 09:00 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
I want your guy thoughts on putting a holley pro dominator tunnel ram with two 1000 cfm hp holleys on my 398 small block. i got all the parts laying around so maybe i should just try it and see how it goes... what do you think? the car is a duster with fully ported w2's 2.08 intake valves 13.2 comp. 630/650 roller cam 1 7/8 headers 3.79 crank.torqueflite with brake dana 60,,4.88 gears 32 tire.6000 stall..indy intake and one 1000 cfm holley hp..car with driver 2750 lbs and runs 9.70 with good air right now,,soooo do you think the tunnel ram will make me happier as in lower et's and would it be as consistent as it is now,,which is very consistent,,,,,thanks
Re: tunnel Ram small Block
[Re: Plymouth340]
#241344
03/02/09 09:26 PM
03/02/09 09:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use to run the Mopar tunnel on the same motor as you are... but I had 2 junk carbs. I am planning on building sheet metal tunnel and using a pair of 1050s, I hope they arent too much.... so I say...try it
Post deleted by Defbob
[Re: MR_P_BODY]
#241346
03/02/09 09:37 PM
03/02/09 09:37 PM
[Re: MR_P_BODY]
#241348
03/02/09 09:50 PM
03/02/09 09:50 PM
[Re: Dragula]
#241351
03/02/09 11:40 PM
03/02/09 11:40 PM
MR_P_BODY
THe 1050's are probably going to be too big, but call quick fuel and get some info from them. A lot of people really like quick fuel carbs, especially the tunnel ram carbs they build.
I had them convert my 1050 dom to E-85 and if I do the tunnel I'll have them do the other 1050 dom I have
[Re: 10 o to go]
#241354
03/03/09 07:51 AM
03/03/09 07:51 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
I can tell you about my setup - mostly street - some strip back to back testing went 12.56 @ 106 with the t-ram and 13.2 @ 102 with a ported cast iron intake 2-390 cfm holley vac secondaries on the t-ram and a holley 780 vac sec on the single. 60' times were 1.74 with the t-ram 1.82 on the 4 bbl mileage was 16 on the highway for the t-ram, never checked with the single with 3.23's and in a street car the setup would act like a single 4, had the scoop not been through the hood you would never know !
[Re: Dragula]
#241357
03/03/09 10:08 AM
03/03/09 10:08 AM
MR_P_BODY
I have the same Holley manifold you show there and sold my Mopar manifold(should have kept it) but I will build a sheet metal one for my new set up
[Re: 10 o to go]
#241358
03/03/09 01:14 PM
03/03/09 01:14 PM
[Re: Hot 340]
#241362
03/03/09 02:48 PM
03/03/09 02:48 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I had one. I was really amazed at the driveability it had. It was hard on the fuel though with the center squirter carbs. But really streetable as far as behaviour was concerned. Never got around to plimbing it up properly, but the car went two tenths quicker and it was a stock stroke 340. As Mr.Peabody kinda noted, you need good carbs.
I had the Weiand T/R also, it was a kit from Summit and came with 2 / 450 mech sec. Holley's. It was on my 67 Cuda. Stock 340 with a Lunati BR II cam. 22 years ago it made for a cool looking combo, and ran fine on the street. Ran 12.20's at the track, and never ran it over 6200 rpm.
I think 2 Dom's are a bit much, but if it's all you have, go for it.
Snap your neck, mega G-force launch, is all I want!
