Re: Small block thrust bearing cap alignment [Re: crash520] #2415490
12/08/17 11:15 PM
12/08/17 11:15 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Sure there could be an error cutting the cap. But start simple first. See if the studs are bound up due to interference between the studs and the holes in the cap, 10 minute repair.
Doug
Re: Small block thrust bearing cap alignment [Re: crash520] #2415887
12/09/17 08:39 PM
12/09/17 08:39 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Doug I know they are so will be looking into that for sure
Re: Small block thrust bearing cap alignment [Re: crash520] #2415924
12/09/17 10:19 PM
12/09/17 10:19 PM
Australia
dodgy Offline
dodgy  Offline
Australia
PM'd you crash I would like to hear back from you, I have the same problem with my 360, 17/32 hole is recommended when going to 1/2 stud but not sure if it may break into the bearing tab locator, I run my new out of box arp studs up in a lathe and found the shank of stud to be out of round aswel. I end up sanding the bearing to reach my clearance but have a 0.006 step on the other side that now has me thinking after reading this post. block was line honed, and clearance changed when caps were torqued up so maybe the caps have been machined bad.
Re: Small block thrust bearing cap alignment [Re: dodgy] #2416154
12/10/17 01:40 PM
12/10/17 01:40 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I am doubting all these blocks were " machined bad". Look at what has been mentioned here, and you will find your problem.
RIP Monte Smith
Re: Small block thrust bearing cap alignment [Re: crash520] #2416324
12/10/17 05:35 PM
12/10/17 05:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
With main studs, you may have to ream the main cap bolt holes slightly larger
