Re: W2 Rocker arms
[Re: 2264PLY]
#2411078
11/30/17 12:59 AM
11/30/17 12:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
SAME arms.. the long valve will sit higher vs the standard.. I have both type heads EDIT The rockers are the same but the valve length is different.. for the W-2/W-5 use the same arms EDIT there is 2 different off sets to the TD ones .700 and a .625 offset
Re: W2 Rocker arms
[Re: 2264PLY]
#2411080
11/30/17 01:19 AM
11/30/17 01:19 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Tell us what version/casting of the w2 head you have?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: W2 Rocker arms
[Re: 70AARcuda]
#2411084
11/30/17 01:32 AM
11/30/17 01:32 AM
Posts: 84 ohio
2264PLY
ohio
I have the long valve econo Part#P4529995
Re: W2 Rocker arms
[Re: MR_P_BODY]
#2411090
11/30/17 01:40 AM
11/30/17 01:40 AM
Posts: 84 ohio
2264PLY
ohio
I don't believe so.They are still in the box.Freeze plugs? Are the valves still readily available?
Re: W2 Rocker arms
[Re: 2264PLY]
#2411091
11/30/17 01:46 AM
11/30/17 01:46 AM
MR_P_BODY
I don't believe so.They are still in the box.Freeze plugs? The newer style has blue plugs that are used after the casting is done.. they did it that way to get a better casting inside... but the rockers are the same.. are yours ported yet
Re: W2 Rocker arms
[Re: MR_P_BODY]
#2411092
11/30/17 01:49 AM
11/30/17 01:49 AM
Posts: 84 ohio
2264PLY
ohio
Brand new untouched castings.Are the valves readily available?Not brand new I've had them for quite awhile. They are probably the older castings.
Re: W2 Rocker arms
[Re: MR_P_BODY]
#2411095
11/30/17 01:54 AM
11/30/17 01:54 AM
MR_P_BODY
What size valves will you be running... you can get a 2.02/ 2.05 or the 2.08 in it but stock version was a 2.02.. also you might want to go with the smaller dia stems.. they help flow... yes the valves are available
Re: W2 Rocker arms
[Re: 2264PLY]
#2411097
11/30/17 01:56 AM
11/30/17 01:56 AM
70AARcuda
las vegas
w5 had blue plugs on the end...W2 some had freeze plugs on the end..
Tony
Re: W2 Rocker arms
[Re: 2264PLY]
#2411100
11/30/17 02:01 AM
11/30/17 02:01 AM
70AARcuda
las vegas
https://books.google.com/books?id=S7rgkZ...995&f=falseread the blue box Econo Head,,,,tells you what length valves are needed... Harland Sharpe sells rockers for the econ head.w2...1.5 or 1.6 ratio. the MP or Crane w2 rocker are no longer made by Crane...Ductile Irons ones are no longer made...Both can be found on Ebay at times..last time I searched ebay there were a couple aluminum ones for sale.
Tony
Re: W2 Rocker arms
[Re: 70AARcuda]
#2411127
11/30/17 03:15 AM
11/30/17 03:15 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
w5 had blue plugs on the end...W2 some had freeze plugs on the end.. And not all W5 heads had the blue plugs. Just later castings did
Re: W2 Rocker arms
[Re: 2264PLY]
#2411537
11/30/17 11:29 PM
11/30/17 11:29 PM
70AARcuda
las vegas
I know that...someone was making a reference to w2 having the blue plugs...which they never did
Tony
Re: W2 Rocker arms
[Re: Medlock51]
#2411782
12/01/17 02:45 PM
12/01/17 02:45 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Valves can be sourced anywhere as mentioned.Almost everything these days is just a SBC valve, or some derivative of one. You can typically make an easy swap out to 11/32 because a guide liner can be used, and its close on size to the 3/8" bore currently. You can also go with full bronze guides if you think thats what you want, albeit more costly.Reducing some area of the valve stem, and reducing valve weights are both good efforts. Dwayne could answer of the top of his head I'm sure, but I have flow comparisons on W2's at the shop, along with RHS/Indy and Enginequest, showing 3/8 vs 11/32 valves. Some arent as big as an advantage as you would think, but I'll take the lighter weight anyday.
RIP Monte Smith
Re: W2 Rocker arms
[Re: 2264PLY]
#2412046
12/02/17 12:51 AM
12/02/17 12:51 AM
Posts: 1,765 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
@2264PLY The valve question is precisely what I had spent some time on, but finally found a valve that is nearly the matching length.
Take a look at the following Manley valves:
1) INTAKE - Manley, 11702-8, Severe Duty Pro-Flo 2) EXHAUST - Manely, 11703-8, Race-Flo
The only challenge here is that these are 11/32 stem diameter. Like you, I have the W2 long valve heads sitting in their original boxes here...not exactly keen on spending the extra $$$ on re-working the heads, but I figured I'd do it right the first time around.
Nothing wrong with the 3/8 stem valves, but if I'm going to spend money on something I might as well aim to save a little weight, thus the move to the 11/32 stem.
Ahh, one other thing, the Manely intake valve is under-cut as well, so apparently a tad better flow at lower lifts - no 1st hand experience here, just a quote/un-quote from their catalog.
Re: W2 Rocker arms
[Re: Diplomat360]
#2412055
12/02/17 01:16 AM
12/02/17 01:16 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The W2's with 3/8 (2.02 valves) will easily flow over 300 with porting work so decide how much performance you need from there. I was extremely happy I didn't spend the extra money to upgrade my valves after my W2's cracked. They are now "leaners" along my garage shop wall.
Re: W2 Rocker arms
[Re: 2264PLY]
#2412162
12/02/17 11:24 AM
12/02/17 11:24 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
The W2s on my 416 flow in the 320s with 2.02 3/8 stem valves. I believe they are MP valves.
68 Barracuda Formula S 340
Re: W2 Rocker arms
[Re: 2264PLY]
#2412173
12/02/17 12:03 PM
12/02/17 12:03 PM
Posts: 170 Wisconsin
Medlock51
Wisconsin
Si will build valves in any size or length you need at very competitive prices. www.sivalves.comCWE is correct... liners work very well and are cost effective. Many builders are using them instead of replacing existing bronze guides.
