Re: 340 Motor Mounts [Re: RapidRobert] #2412636
12/03/17 12:55 PM
12/03/17 12:55 PM
moparx Offline
moparx  Offline
Originally Posted By RapidRobert
hope this helps.
It sure does & I was wishing I had asked that very question when I posted above as I have spools on the stock car & it reminded me that it would be advantageous if I filled em.
when i fill those holes, i make a cardboard pattern that fits around the bottom side [doesn't matter which side, as you will do this while mount is on it's side], then i cut a piece of wax paper to fit this pattern. tape the wax paper/cardboard [i just use a couple of pieces of double side tape] pattern to the outside of the mount, lay it on it's side, and fill the holes. let the urethane cure according to the directions. the wax paper then peels off the bottom side of the urethane, leaving a smooth surface. makes quite a difference in the mount "stiffness". if you don't have any wax paper, other stuff to use is a thin coating of wheel bearing grease, silicone grease, etc. the object is to have something the urethane will not stick to when it sets up.
beer
Re: 340 Motor Mounts [Re: YO7_A66] #2413930
12/05/17 11:51 PM
12/05/17 11:51 PM
3
340clone Offline
340clone  Offline
After breaking two driver side auto store mounts, I replaced it the third time along with the Schumacher mount. No problems after that.
Re: 340 Motor Mounts [Re: 340clone] #2414491
12/07/17 12:07 AM
12/07/17 12:07 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
340C:
I am planning on checking my current mounts. If they are good, then I will be adding the Schumaker torque strap too with the stock mounts.
Thanks!
Re: 340 Motor Mounts [Re: YO7_A66] #2416572
12/11/17 12:45 AM
12/11/17 12:45 AM
3
340clone Offline
340clone  Offline
I meant to say Schumacher strap but you got it. Yep-can't go wrong with that set up.
Re: 340 Motor Mounts [Re: YO7_A66] #2417128
12/12/17 01:37 AM
12/12/17 01:37 AM
roanoke va
kbcuda Offline
kbcuda  Offline
roanoke va
