Re: Having the common tranny issues with 46re, need guidance
[Re: Adam71Charger]
#2412059
12/02/17 01:26 AM
12/02/17 01:26 AM
Posts: 6,020 Salem
Grizzly
Moparts Proctologist
Salem
That sucks Adam, but all it cost you is your time. Always do the free stuff first. I'm surprised that check engine light came on so quick, did you even put it in gear or try to drive it? Is there any change in the code list?
Mo' Farts
Moderated by "tbagger".
[Re: Adam71Charger]
#2412146
12/02/17 09:32 AM
12/02/17 09:32 AM
Posts: 5,962 ohio
ruderunner
ohio
The light coming on immediately indicate an electronic problem. What codes came back?
Angry white pureblood male
[Re: Adam71Charger]
#2413849
12/05/17 09:58 PM
12/05/17 09:58 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
It still kinda bothers me that my trans relay has 5 prongs but sits in a 4 terminal slot, so basically the middle prong doesnt connect to anything. Could this be the wrong relay? 20171130_132650 by Richard Bailey, on Flickr 20171130_132708 by Richard Bailey, on Flickr 20171130_132728 by Richard Bailey, on Flickr And here is a shot of the stamped code on the driver side. 20171130_134528 by Richard Bailey, on Flickr
[Re: Adam71Charger]
#2413882
12/05/17 10:53 PM
12/05/17 10:53 PM
Adam71Charger
I think Im going to order the complete solenoid kit from cascade, that way when I drop the pan, if there's no mess, Ill install it, if there is a mess, I send it back and look at rebuild options. I know this is not the most graceful way to handle the problems, but these parts in the kit are the culprit in so many of the problems with the RE transmissions that Im willing to bet the kit solves my issues.
[Re: Adam71Charger]
#2414016
12/06/17 01:49 AM
12/06/17 01:49 AM
Posts: 6,020 Salem
Grizzly
Salem
Sounds like a plan, I've read into solonoid pack replacement but so far have not had to do it on my RE.
When you get it drained, take out the output speed sensor and clean the tip. If I remember right it's a small magnet and bits of metal will get to it. That may be why you are getting that code.
Don't take it out before you drain it........or you'll get a bath. Damhik.
Mo' Farts
[Re: Adam71Charger]
#2435328
01/16/18 12:14 AM
01/16/18 12:14 AM
Adam71Charger
Ok I ordered the kit, it arrived, I unhooked the negative battery cable and dropped the pan. Fluid was clean and the magnet had barely any gunk on it.
I installed the 46RE Governor Pressure Service Kit 2000 Up from cascade.This included the governor (governor pressure transducer), the shift solenoid (governor pressure solenoid), the gasket for the housing of those 2 units, the 3-4 accumulator spring, the tail shaft speed sensor, the new filter and the new pan gasket. Filled it with atf+4.
I also bought a mid grade code reader.
I hooked up the battery and fired it up. Within 10 seconds or so, the check engine light came back on. I cussed and got in and took it for a ride. Again, when put in drive it starts out super slow and I figure this either means it’s starting out in third or something is wrong with the torque converter . But before I could only manually down shift to second and it would never going to first and also overdrive was not working.
This time again when put in drive it started out really slow just like before But this time I could manually shifted into every gear first second and third but I didn’t get it going fast enough to see if it went into Over Drive. When put in the first it kind of feels like it doesn’t catch until you give it a fair amount of throttle but nonetheless it went in the first and second and third manually.
First read of codes: P0743 TCC solenoid circuit, P0753 1-2/4-5 Solenoid circuit, P1764 governor pressure sensor low, P1765 1. Switched battery failure 2. Trans power relay circuit
I cleared the codes and turned it back on, again the check engine light came on in about 10 seconds and I took it for a drive. It seem to drive a little bit better.
Second read of codes: P0743 TCC solenoid circuit, P1764 governor pressure sensor low, P1765 1. Switched battery failure 2. Trans power relay circuit
With one of the codes disappeared, I switched out the trans relay with another relay and no change. I’m starting to think I have a short somewhere. I have heard of the downstream O2 sensor Circuit causing short problems as it runs in the same harness as the transmission wiring. Or maybe my TCC solenoid is shot and I should’ve bought the full kit that included that!!!
What do you guys think? What should my next movie?
[Re: Adam71Charger]
#2435766
01/16/18 05:28 PM
01/16/18 05:28 PM
Posts: 6,020 Salem
Grizzly
Salem
I think the next move is:
1. Manually shift it, drive for a bit, get some miles on that fluid, let your new filter catch what it can and do it's job. You say you have'nt been in 4th yet: make an excuse to go for a road trip. Your tc locks in 4th (and will in 3rd if you press the "overdrive off" button) and needs to get run in top gear for some miles. Give us an update.
2. Change the tcc solonoid-I really think this is the problem now. I think that's why it's dragging it's ass when you take off: t/c not unlocking, solonoid burnt.
3. New torque convertor.
4. There's a transmission in Portland with 132,000 miles for $830.00.
Mo' Farts
[Re: Adam71Charger]
#2435783
01/16/18 05:49 PM
01/16/18 05:49 PM
Posts: 3,110 Michigan
A727Tflite
Like I stated earlier - you have circuit failure codes, fluid and temperature has nothing to do with these codes. Look the harness over real good for chaffing or damage. From the controller down to the trans. Carefully pull the connectors loose and clean and inspect for corrosion, both the female and male ends. Switched battery failure stands out like a sore thumb. It's dragging because you are in default third gear. If you can pull it in to low and it accelerates like it normally would that confirms default/third gear start. Converter has nothing to do with your problems at this point. And yes the O2 circuit can wreak havoc on trans controls due to the sharing of the harness at the splice.
[Re: A727Tflite]
#2435917
01/16/18 09:30 PM
01/16/18 09:30 PM
Adam71Charger
Look the harness over real good for chaffing or damage. From the controller down to the trans. ... And yes the O2 circuit can wreak havoc on trans controls due to the sharing of the harness at the splice.
Where/what is the ‘controller’? Is it a bad o2 sensor or bad o2 sensor circuit that causes the problems?
[Re: Adam71Charger]
#2435995
01/16/18 11:22 PM
01/16/18 11:22 PM
Posts: 6,020 Salem
Grizzly
Salem
But it is obvious someone has cut the pink wire out of the middle connector of the PCM and At the relay box and jumped it. I don’t know if that has anything to do with the transmission but I’ll find out as I trace these wires Yeah. You failed to mention this. ![smirk smirk](/ubbthreads/images/graemlins/custom/smirk.gif) Get this issue looked after first.
Mo' Farts
