Re: ok trans(727) problems ( update better pics)
[Re: YbNoRmAL]
#24098
05/11/06 10:20 AM
05/11/06 10:20 AM
there's some good tech info here. I made it so this thread cannot disappear , then when it is done it will be moved to the tech archives.
Re: ok trans(727) problems again HELP
[Re: VernMotor]
#24100
05/11/06 11:35 AM
05/11/06 11:35 AM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Looking at your good picture of the governor support... its pretty evident that something came thru the main lube feed to the output shaft based on the metal displacement from that hole towards the small feed that lubs the rear drum. That would seem to indicate something comming from the cooler area.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
