Re: The good, bad, and ugly...deep oil pans for a 440
[Re: 1fastrunner]
#240980
03/05/09 12:30 AM
03/05/09 12:30 AM
I dont have a decent picture but when I did the motor for the practice car for the NASCAR RETURNS TO LEMANS project(Christophe Schwartz and friends)because the car was a road racer and many of its miles would be on normal streets but under racing circumstances i didnt want a pan hanging down so i would get a phone call in the middle of the night. (Halfe mich, Don). I bought a Hemi repo pan brand new. I bought two 45 dergee bends of 2 1/2 inch od exhaust tubing. I sliced the bends so they fit on the side of the hemi pan but no longer than the sump. I made a large window in each side of the pan, flush at the bottom and then welded the slices of the bends on. I made sure the oil could get in an out easily but still had some baffeling at the ends. I cleaned it till i had nighmares about it and when i was satisfied I painted it and installed it with the Mopar windage tray. The block which is a 400 I had redrilled for a hemi pick up but I used the crooked short one from MP. Not the long straight one. It worked out perfect and has stood 3 years of abuse in Europe. It fits the stock chassis (72 Charger. ) and holds 7 QTZ. It meets the critieria of a Qt of oil for every 1000 RPM. That is my rule of thumb since I cammed this engine to make all its power under 6500 because if you dont finish you cant win. I think I would make myself one sometime for my max wedge car as well. I like the idea of having the extra capacity , having it stored away from the spinning crank and having no worries about hiting anything wth the oil pan no matter what happens.In my cruiser a 63 Dodge max Wedge 426 I have a homebuilt hanging down about 1 inch. It wuld be nice to have the same volume with out the worry of wacking the pan on something or hitting something left on the road like a big chunk of firewood or even a big racoon. Don
[Re: Flite_727]
#240981
03/05/09 01:05 AM
03/05/09 01:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
since we're all posting pics., does anyone have a good pic. of what the "hinge" side of a trap door system looks like? (sorry for the hijack)
Sorry no pic but its nothing trick, a few holes on the wall that goes across the pan then on the rear side of the wall is just a flat plate with a wire for a top hinge. The plate lays flush against the wall to seal off the holes when the oil sloshes forward on braking , swings open on acceleration ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#240982
03/05/09 08:12 PM
03/05/09 08:12 PM
Posts: 1,448 right between milan dragway & ...
Flite_727
well, what i was really curious about, was if there's a stop of some sort to keep the trap door from going past 90*. i would think that it would be a nessisity(sp) to keep the door from being held open by oil sloshing back towards the front. ![](/ubbthreads/images/graemlins/shruggy.gif)
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
[Re: Flite_727]
#240984
03/06/09 12:11 AM
03/06/09 12:11 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Yes. Mine has the hinge pin that extends out and is bent such that it only allows it to open so far. I do not have a picture of it.
