Re: Does Anyone Make Light Weight E body Spindles?
[Re: 590 Challenger]
#2408241
11/24/17 02:13 PM
11/24/17 02:13 PM
Posts: 4,213 New York
polyspheric
New York
I'm sure there are places that can stand to be dieted safely, but I've seen too many "lightened" suspension parts that look like suicide attempts. Got a good picture? I may be able to spot something.
Boffin Emeritus
[Re: AndyF]
#2408272
11/24/17 03:17 PM
11/24/17 03:17 PM
Posts: 2,094 central texas
krautrock
central texas
The late model FMJ knuckles are significantly lighter than the early knuckles. It appears that someone at Mopar finally took a class on FEM and used it on those knuckles. The weight savings isn't huge, maybe 1.5 lbs per side but it is already done for you. i had the spindles off my car recently (FMJ spindles) and they didn't seem a like an excessively heavy part given their purpose... another question, with the FMJ spindles being a bit taller than the A body spindles, does that equate to slightly less negative camber being dialed into the suspension?
#2408280
11/24/17 03:40 PM
11/24/17 03:40 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Stock spindle is only 5 lbs.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2408310
11/24/17 04:34 PM
11/24/17 04:34 PM
Posts: 493 Parts unknown
590 Challenger
Parts unknown
Stock spindle is only 5 lbs. Thanks guys, I would have figured a lot more than 5 lbs. I still need to lose about 200 pounds, serching
#2408335
11/24/17 05:37 PM
11/24/17 05:37 PM
dogdays
#2408446
11/24/17 11:15 PM
11/24/17 11:15 PM
polyspheric
New York
If I were the track/racing venue attorney, I would make sure that "modifications to suspension parts constitute participatory liability assigned to the driver/owner in a crash" appears in the release form. If it's neither OEM nor SEMA they will blame you if it fails.
The solution: blend and radius any metal removal and repaint!
Boffin Emeritus
#2408466
11/24/17 11:56 PM
11/24/17 11:56 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I took a pound out of each spindle on my car. Then got yelled at on here. I run wilwoods so no need for all that metal for caliper bracket
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2408471
11/25/17 12:20 AM
11/25/17 12:20 AM
Posts: 3,877 Smyrna, South Carolina
STEFF
I took a pound out of each spindle on my car. Then got yelled at on here. I run wilwoods so no need for all that metal for caliper bracket Shame on you Ray. Make sure you let the track owners know, wherever you race.
#2408488
11/25/17 12:53 AM
11/25/17 12:53 AM
STEFF
I already have FG hood, fenders , trunk lid, doors valances, lexan windows, tube k member, dash is a 5" x 8" piece of aluminum. Only tach and oil gauge. 1 seat no interior Whats it weigh?
#2408524
11/25/17 02:27 AM
11/25/17 02:27 AM
sixpackgut
Charleston
I already have FG hood, fenders , trunk lid, doors valances, lexan windows, tube k member, dash is a 5" x 8" piece of aluminum. Only tach and oil gauge. 1 seat no interior When I was trying to lose weight on my 70 challenger I lost like 300 lbs by building an A body
[Re: sixpackgut]
#2408564
11/25/17 05:00 AM
11/25/17 05:00 AM
Posts: 20,230 Park Forest, IL
slantzilla
Park Forest, IL
When I was trying to lose weight on my 70 challenger I lost like 300 lbs by building an A body And BOOM! goes the dynamite........... ![ozbbq ozbbq](/ubbthreads/images/graemlins/custom/OzBBQed.gif)
[Re: STEFF]
#2408605
11/25/17 11:33 AM
11/25/17 11:33 AM
Posts: 4,715 Wichita
GY3
Wichita
Have you removed the safety crash bars out of the doors? They're pretty heavy. I see he already has FG doors, but FYI to those contemplating crash beam removal, it is 15 lbs. per door.
