Re: Tremec TKO in 69 B-body question [Re: DAYCLONA] #2410255
11/28/17 06:11 PM
11/28/17 06:11 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
Originally Posted By DAYCLONA
Originally Posted By cudaerik
So there is no prying or anything like that after the two Allen head bolts are removed? is it a rod with a ball on the underside of the shifter tower that goes into a cup on the [censored] dogs?
Yes...very simple, nothing to be afraid of, the shift tower will even work/function if you install it 180 degrees off, but it will put the tower nub flat on the passenger side and offset the shifter handle towards the passenger side
Finally bought an app to make pics smaller. Install was pretty easy. There was some extensive tunnel mods., we cut out the 4 speed hump and rolled the metal to fit. They are templates to help. non original 4 speed car. I Have to use an E-body shifter.
A370810D-C5A1-4B88-8028-AC0F3FD9A4B1.jpeg1982FE85-5C08-42F7-B0AE-C133C00D5D1F.jpeg5367C3C4-23CB-42DB-A119-483F319578A7.jpeg349F6A60-F119-440E-9509-7217D42F5019.jpeg
Re: Tremec TKO in 69 B-body question [Re: 70RT Charger] #2410270
11/28/17 06:55 PM
11/28/17 06:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70RT Charger, are you using an E body shifter because you want to?
As the T56 shifter location you appear to have, looks close to the 68-70 B body TKO shifter location as seen in these pics, I'm comparing the factory floor shape sections between the 2 pics, and they appear "spot on" in B body shifter location?
Mike
Re: Tremec TKO in 69 B-body question [Re: DAYCLONA] #2413088
12/04/17 02:21 PM
12/04/17 02:21 PM
southern Idaho
moparcyco Offline OP
southern Idaho
Sorry to bump back to top. I got this cut out and fit just wanted to post a picture of the cut for anyone who may need a reference pic.
Re: Tremec TKO in 69 B-body question [Re: moparcyco] #2413198
12/04/17 06:11 PM
12/04/17 06:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks for the update, gee... AP has a rather new approach to the shifter tower, hope it's an improvement over the past set ups?
Mike
Re: Tremec TKO in 69 B-body question [Re: DAYCLONA] #2413277
12/04/17 09:03 PM
12/04/17 09:03 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Mike
Looks like it would fit into an automatic floor pan?
