Re: Edelbrock AVS2 Carb [Re: bee1971] #2469262
03/20/18 05:42 PM
03/20/18 05:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
from what I've seen the annular booster is dimensionally the same as non-annular; unlike holley. just swap the clusters.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2601950
01/05/19 04:03 PM
01/05/19 04:03 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
They talk about it (800 AVS2) in there latest blog like it’s already available on Edelbrocks website
But But But - I don’t see it anywhere
Quotes
"We followed up this year with a new 800cfm AVS2 that provides optimum performance for high-horsepower applications on both small- and big-block engine applications."
"The Edelbrock AVS2 Series Carburetor is available in 500cfm, 650cfm, and now 800cfm for high-horsepower applications"
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Edelbrock AVS2 Carb [Re: bee1971] #2601953
01/05/19 04:05 PM
01/05/19 04:05 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
Tried calling Edelbrock yesterday - That went no where on the 800 AVS2
Siberian Huskies
Re: Edelbrock AVS2 Carb [Re: bee1971] #2602019
01/05/19 07:05 PM
01/05/19 07:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Classic manufacturer tech line story.
“Avs.....what?”
The 650 shows in stock at Summit though.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2602296
01/06/19 02:16 AM
01/06/19 02:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually I was wrong about the Eddy carb as its the secondary side that uses the extra fuel circuits. Looks like it works like the system many Quadrajets use. I said primary earlier but that was a different carb as when I looked at this again I saw I was wrong as its the secondary side that pulls this extra fuel as the air valve starts to open. Ron
https://www.manualslib.com/manual/42643/Edelbrock-Performer-Series-1403.html?page=7#manual
Re: Edelbrock AVS2 Carb [Re: lewtot184] #2602412
01/06/19 02:06 PM
01/06/19 02:06 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
You cant swap the new boosters from the AVS2 version to the old standard 800. This was straight from Edelbrock when those were first released.
Re: Edelbrock AVS2 Carb [Re: bee1971] #2603921
01/09/19 03:09 PM
01/09/19 03:09 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have found that my 800 thunder likes to run with the same total fuel “flow” but likes to be rich on primary side and lean on secondary side. By the chart I should be able to lean the front and richen the rear to be more balanced. NOPE!
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
