Page 2 of 3 1 2 3
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: fastmark] #2406250
11/20/17 08:57 AM
11/20/17 08:57 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Lol
I installed a 035 mig welder tip in the return hose after
connection - it fit snug in the rubber return line
Havent lost fuel pressure Or vapor locked in a while.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: Furious440] #2406384
11/20/17 04:16 PM
11/20/17 04:16 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
(Put a three outlet fuel 'filter' in there and fuggitaboutit...
Been running one for many moons...
Zero issues...
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: RSNOMO] #2411838
12/01/17 04:13 PM
12/01/17 04:13 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
After reading this post I decided to check mine as I've always had issues starting the car after sitting after a period of time. I actually had to put fuel directly into the fuel bowl for it to start. Heres the pic of the return line, full hole, maybe this is my issue. When I disconnected the hose it was full of fuel.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: Furious440] #2411839
12/01/17 04:14 PM
12/01/17 04:14 PM
Chicago
PurpleBeeper Offline
Chicago
Sorry to Hijack, but I have a related question. I'm running a 440 six pack that does suffer from vapor lock issues. I have an electric blue Holley pump regulated to 6psi.
I was thinking about using the stock fuel line as my return. Since I'm not running a mechanical pump at all, will adding the vapor separator (with .060" hole) help me???
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: gygeneral] #2412196
12/02/17 12:42 PM
12/02/17 12:42 PM
California
biggE Offline
biggE  Offline
California
There should be zero fuel in the return line. The other issue that I believe is with the fuel separator that you have is that the tube length in the unit is to short. Either way I would replace it.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: biggE] #2412321
12/02/17 06:13 PM
12/02/17 06:13 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I ordered a new one from Frank B.. I'm going to open this old one up and look inside when I remove it from the car.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: Furious440] #2412356
12/02/17 07:52 PM
12/02/17 07:52 PM
WA
tman Offline
tman  Offline
WA
Good idea opening it up. Do send pics of it.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: gygeneral] #2412736
12/03/17 06:03 PM
12/03/17 06:03 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
There were many bogus separators in the marketplace. Besides the return line having no orifice, there was no screen inside and the tubes were the incorrect length!!!! This is one I bought for my 6bbl - junk. Your return tube looks like mine - with no orifice, so I suspect it is a bogus one.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: tman] #2412866
12/03/17 11:27 PM
12/03/17 11:27 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I opened mine up today, the orifice is wrong but the tubes inside appear to be the correct lenght and has a screen.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: Furious440] #2413527
12/05/17 12:50 PM
12/05/17 12:50 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’m not an expert but I have my oem one from my Superbird that I have measured and compared to two ones that I have bought. The first was from Year One and had the big (.115 ) hole in the return line. Using a wire with a hook on it, I determined that all three units had the exact same length tubes as my oem. The other unit I bought had the proper size hole as the oem one did. It was not made as clean but it was .060. I’m not sure if it has the screen or not. I bought three of them and just used one on my Charger to replace the new and wrong Year One piece. I’ll see if I can find where I bought these three from. I’ll try and post a picture as well.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: Furious440] #2413533
12/05/17 12:57 PM
12/05/17 12:57 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This new phone will not let me see the attachment but the oem is on the left, the small hole is in the middle and the big hole YO unit is on the right.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: fastmark] #2413857
12/05/17 10:03 PM
12/05/17 10:03 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
You may find that even the .060" hole can be too big. I discovered on my engine that the larger hole allowed a 2+ psi drop on the fuel pressure measured at the carbs. I soldered the hole closed and drilled it out to .030". My pressure loss was now less than 1 psi and still large enough to pass any vapor and fuel back to the tank. Zero issues even in 95+ degree heat.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: 68jim] #2413942
12/06/17 12:02 AM
12/06/17 12:02 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I agree- 0.060" is too large. I soldered mine and drilled with a 0.040" drill.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: RealWing] #2414019
12/06/17 01:53 AM
12/06/17 01:53 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Do you need that return line at all. Isn't that part considered a polution control device. What would happen if you blocked it all together.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: gygeneral] #2414031
12/06/17 02:16 AM
12/06/17 02:16 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It's there to prevent vapor lock, but also, if you plugged it up, it could cause the fuel pressure to get to high.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: 71birdJ68] #2414610
12/07/17 11:27 AM
12/07/17 11:27 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
what about the cars that only have a fuel filter, how do they get away with no return line. I guess it must be vented somewhere then?
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: gygeneral] #2415749
12/09/17 03:30 PM
12/09/17 03:30 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
they vent from boilin over and floodin your engine when it sits on a hot shut down .
i was very sucesful with the mig welder tip ..
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: biggE] #2443699
01/30/18 10:34 PM
01/30/18 10:34 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I disagree
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: sogtx] #2444455
02/01/18 02:47 AM
02/01/18 02:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I disagree
Yeah E that's not right. It's a fuel return line.
Re: '71 440 HP VAPOR SEPARATOR experts please! [Re: Morty426] #2444935
02/01/18 11:34 PM
02/01/18 11:34 PM
California
biggE Offline
biggE  Offline
California
I disagree [/quote]
Yeah E that's not right. It's a fuel return line. [/quote]
It's actually a vapor return line. Fuel can run through the line but if there's fuel in it something is likely wrong like a blocked fuel line or clogged separator.
Page 2 of 3 1 2 3
