That is the intake manifold I’m running.
Part of the confusion on the float level is holley reccoemnds the fuel to be at the bottom of the sight glasses, quick fuel reccoemnds having the fuel half way up the sight glasses.
So I did have the float level at the bottom of the sight glasses, I noticed when it was cold out especially that it was pretty lean at part throttle.
Specially after I slowed my advance rate down in my distributor.
So I raised the floats to half way up the sight glasses and that solved the lean spot at part throttle and made the engine feel like it was running better, specially when it’s cold.
So I’m tninking since I raised the float level to what quick fuel reccoemnds that I probly
Should increase the idle air bleeds to lean out the idle and off idle circuit a little bit.
