Re: Broke my K Frame
[Re: astjp2]
#2406602
11/21/17 12:27 AM
11/21/17 12:27 AM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
When you pull the kframe, take it to a machine shop and have it hot tanked, less things to burn when welding. Tim That's one of the reasons I have my own hot tank, but I really need to clean it out soon.
[Re: astjp2]
#2407193
11/22/17 02:11 AM
11/22/17 02:11 AM
Posts: 4,179 California
mickm
California
When you pull the kframe, take it to a machine shop and have it hot tanked, less things to burn when welding. Tim Good advice, but won't need to. It was well cleaned out when I put it in, had it powder coated before going in. Will just have to clean it well for welding.
[Re: mickm]
#2407613
11/22/17 11:23 PM
11/22/17 11:23 PM
Posts: 8,407 Highland, MI.
Sunroofcuda
Highland, MI.
Got down under the car today, and it is an ugly sight. The outboard side of the perch still looks like it is attached to the k frame, although a little hard to tell. The inboard side is completely separated from the frame, and bent down towards the engine, at least a few inches out of place.
So I'm going to have to bend it back into shape before it can be welded on. I may remove it and add a little structural bracing, just to be sure. Bent metal is bent metal...
I hope to have it out in the next few weeks, but we'll see... Mick, if you need to replace the K-member, you want a good rust-free one. Let me know - I have a few contacts still from TX. & AZ. that should have some good 1970 K-members. From the way you describe it, I would not even bother trying to repair it.
[Re: Sunroofcuda]
#2412890
12/04/17 12:47 AM
12/04/17 12:47 AM
mickm
California
Well, got started this weekend.
Now, you have your high tech way of doing things, and then you have your "whatever is laying around the garage" way of doing things.
I thought about buying a lift thingy that was only $60 shipped, but then I thought that after that it would just be sitting around, taking up space and collecting dust.
So, a few 4x4's, 2x4's and some chain, and here it is!
The perch is completely separated from the k frame. Don't have it out yet, but close. Wow! Busted that thing right off.
On another note, it's been a long time, and I don't have anything specific. How do I get the torsion bars out? And yes, all of the preload is off.
[Re: mickm]
#2413530
12/05/17 12:56 PM
12/05/17 12:56 PM
Posts: 669 Los Osos, Ca
CKessel
Los Osos, Ca
Watch my video on YouTube about t-bar removal. The one by Roll Another One Fabrications.
Carl Kessel
[Re: astjp2]
#2413786
12/05/17 08:05 PM
12/05/17 08:05 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
When you pull the kframe, take it to a machine shop and have it hot tanked, less things to burn when welding. Tim Good luck finding a machine shop with a hot tank in California.
[Re: Morty426]
#2413870
12/05/17 10:33 PM
12/05/17 10:33 PM
Posts: 1,250 North Carolina
469runner
North Carolina
I would highly recommend replacing the whole thing with the proper Hemi K frame This. Mega Parts will set you up. It will place the engine perfectly in the engine compartment.
[Re: Pntastar69]
#2414056
12/06/17 04:24 AM
12/06/17 04:24 AM
mickm
California
Just removed mine over the weekend. Support the LCA's w/a jack, loosen both LCA pivot nuts, back off the height adjusters, and give the LCA's a whack w/hammer and block of wood rearward. The bars should pop right out. That worked well for the right side, left side I can't move at all. I've triple checked that all nuts are loose, clip is out at the back, but it just doesn't want to move. I put these bars in about 10 years ago, and the car hasn't seen weather, no rust or anything, but something is keeping that LCA from moving, or the bar from coming out.
[Re: CKessel]
#2414058
12/06/17 04:26 AM
12/06/17 04:26 AM
mickm
California
Watch my video on YouTube about t-bar removal. The one by Roll Another One Fabrications. I did check this out. I played with moving the adjuster up and down, didn't help, although I didn't work it up and down and find the middle point. I'll try that.
[Re: mickm]
#2414140
12/06/17 12:44 PM
12/06/17 12:44 PM
CKessel
Los Osos, Ca
You need to get the pressure off the hexes of the bar and the sockets, then they should slide out. Factory bars have a bit of a helix/twist in the hex which helps to keep them in. Think of it as a fastener stuck in your socket, after putting some grunt to it, that you have to change the rotation back the other way for it to pop loose. Loosening up the control arm shaft nut, say a little less than 1/4", then thumping it back gets it unstuck from the k and helps it to rotate freely to further aid getting the bars free.
Carl Kessel
[Re: mickm]
#2414146
12/06/17 12:57 PM
12/06/17 12:57 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
Just removed mine over the weekend. Support the LCA's w/a jack, loosen both LCA pivot nuts, back off the height adjusters, and give the LCA's a whack w/hammer and block of wood rearward. The bars should pop right out. That worked well for the right side, left side I can't move at all. I've triple checked that all nuts are loose, clip is out at the back, but it just doesn't want to move. I put these bars in about 10 years ago, and the car hasn't seen weather, no rust or anything, but something is keeping that LCA from moving, or the bar from coming out. Try jacking up the LCA a bit more. You gotta find the sweet spot where it will slide out.
[Re: Kern Dog]
#2414155
12/06/17 01:17 PM
12/06/17 01:17 PM
469runner
North Carolina
You guys have a stockpile of these rare 1970 only K members? From what I understand, the 1970 model is unique, the 71-71 fits but the steering box mounts are angled slightly. I purchased a 1970 Hemi K-frame from Mega Parts. They take a small or big block frame and cut the mount perches off and weld HEMI perches on. They use a jig so the dimensions are spot on. They are usually made to order so don't let the out of stock keep you from calling in. Sometimes they will require a core to be sent in. http://www.megapartsusa.com/proddetail.asp?prod=MP-HKF103
