Re: Deep Engine Thoughts
[Re: AndyF]
#2403802
11/15/17 12:50 AM
11/15/17 12:50 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
It will get about 4 mpg. DOUBLE what I get in my Dart with a 4150. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) The old cars were great because they were topped off daily with cheap primo before going home from work. The gas stations were always full of bull, especially when you drove in to the isle, driving a striped, muscle car with high impact paint. At night, under the lights, was even cooler. Stopping for a cold beverage wasn't unheard of. So my take on this is that if you are going to daily drive an old car, with any "performance" mods at all, get ready to pay the piper. Even the newer, high powered cars burn GAS! Big time! You might get 20 idling down the road in overdrive in a new Corvette. Only because I think it would be the lightest of the bunch. I know nothing about foreign cars and their engines.
[Re: 6PakBee]
#2403937
11/15/17 01:07 PM
11/15/17 01:07 PM
Posts: 59 Florida
Sweet5ltr
Well, efficiency is relative. Here are two heavy hitters.
My father has a 99' K2500 4x4 Suburban. Gen VI 454 BBC. It's rated at 290hp @ 4,000 RPM & 410 lb/ft @ 3,200 RPM. Vehicle weight - 5,600#. 4.10 gears with 31" tires. 4l80e transmission (4 speed).
I have my 15' Ram Power Wagon. 6.4/392 Hemi. It's rated at 410hp @ 5,600 RPM & 429 lb/ft @ 4,000 RPM. Vehicle weight - 7,000#. 4.10 gears with 35" tires. 66rfe transmission (6 speed).
BOTH of these trucks get 10mpg around town. Both get nearly identical fuel economy on the interstate. One weighs 1,400# more than the other, and makes 120 more HP and 19 lb/ft of TQ. Cylinder deactivation rarely if ever occurs, as I leave my truck in tow-haul mode. This shows how efficient newer drive lines truly are, even a watered down 392 Hemi with eagle heads (not Apache) is relatively efficient, for the most part, due to having 6-gears versus 4-gears.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
