Page 2 of 3 1 2 3
Re: MSD distributor taking timing out [Re: mopar dave] #2403639
11/14/17 07:19 PM
11/14/17 07:19 PM
Washington
madscientist Offline
Washington
Originally Posted By mopar dave
What size is the msd distributor shaft?
I think...going by my used up memory...the shaft should measure .485-.490 so a set collar with a 1/2 hole will work.
Forgot to mention they usually only have one set screw. I put two more in the collar so I have three. I'm just chicken like that.
Re: MSD distributor taking timing out [Re: madscientist] #2403646
11/14/17 07:33 PM
11/14/17 07:33 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Ill see if i can find a collar that fits snug on the shaft. Thanks
Re: MSD distributor taking timing out [Re: mopar dave] #2403648
11/14/17 07:38 PM
11/14/17 07:38 PM
Mt Morris Michigan
Mt Morris Michigan
What i could do is take the roll pin out of the collar thats on the msd shaft now and see if the guys at the local nut and bolt store can match it up another collar to that one, but with a screw in it..
Re: MSD distributor taking timing out [Re: mopar dave] #2403968
11/15/17 02:20 PM
11/15/17 02:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I shimmed mine years ago to have .002-.003 up n down movement and added a rubber/nylon bushing instead of the collar and it compresses nicely when the lock down is tightened. I also added a new bronze gear and had Pettis machine the difference off the gear to add a 3-piece torrington bearing deal and the timing is more stable than ever..........The bronze bushing and gear don't seem to play well together and wear quickly......... thumbs
Re: MSD distributor taking timing out [Re: Thumperdart] #2403972
11/15/17 02:26 PM
11/15/17 02:26 PM
Mt Morris Michigan
Mt Morris Michigan
Ok thanks Dom. Ill see if i can find something in nylon instead of metal.
Re: MSD distributor taking timing out [Re: mopar dave] #2403989
11/15/17 03:05 PM
11/15/17 03:05 PM
Washington
Washington
Dom has a good point about taking the play out of the distributor shaft as well. I always do it, just forgot to mention it.
If you do both your timing will be rock steady.
Re: MSD distributor taking timing out [Re: madscientist] #2404036
11/15/17 05:06 PM
11/15/17 05:06 PM
Mt Morris Michigan
Mt Morris Michigan
Its been in my plan to tighten it up to .005. I have to remove the pinned collar any way. Hoping to really dial the timing in.
Re: MSD distributor taking timing out [Re: mopar dave] #2404072
11/15/17 05:57 PM
11/15/17 05:57 PM
an8sec70cuda Offline
Go to Tractor Supply and get a 1/2" collar for $1.25...unless you just like paying $20+ for the same part. I've had one in my hemi for probably 5 years now. Fixed the same issue you're having.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: MSD distributor taking timing out [Re: an8sec70cuda] #2404120
11/15/17 07:01 PM
11/15/17 07:01 PM
Mt Morris Michigan
Mt Morris Michigan
Does the tsc collar fit the shaft snug?
Re: MSD distributor taking timing out [Re: mopar dave] #2404127
11/15/17 07:13 PM
11/15/17 07:13 PM
IIRC it fit pretty good. Like I said, been in there for around 5 years...no trouble. Must be good.
CHIP
Re: MSD distributor taking timing out [Re: mopar dave] #2404133
11/15/17 07:20 PM
11/15/17 07:20 PM
Washington
Washington
They don't have to fit real tight.
Like I said...I'm a chicken so I add two more set screws. I've never had one come loose and I've done probably 40 of them over the years.
Re: MSD distributor taking timing out [Re: madscientist] #2404137
11/15/17 07:24 PM
11/15/17 07:24 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. Then ill just go to tsc then. I may already have one. Just have to go thru my nuts and bolts can. Second thought, ill go to tsc. Its quicker.
Re: MSD distributor taking timing out [Re: mopar dave] #2404149
11/15/17 07:47 PM
11/15/17 07:47 PM
Washington
Washington
I've spent hours looking for a bolt I could have run to town and bought. Someday I'll organize that stuff better.
Re: MSD distributor taking timing out [Re: madscientist] #2404162
11/15/17 08:11 PM
11/15/17 08:11 PM
Mt Morris Michigan
Mt Morris Michigan
Believe me, i understand.
Re: MSD distributor taking timing out [Re: mopar dave] #2404226
11/15/17 10:02 PM
11/15/17 10:02 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Anyone have a a reference photo they can post? I am pretty sure I understand but a Photo would be great. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: MSD distributor taking timing out [Re: mopar dave] #2404284
11/15/17 11:45 PM
11/15/17 11:45 PM
North America
K
kwikblownhemi Offline
K
North America
If you had no problems with a Firecore distributor in the same engine, my money is on the MSD as the culprit. I have seen several in the past few years that had crazy timing issues. MSD quality isn't what it used to be.
Re: MSD distributor taking timing out [Re: Wookie316] #2404299
11/16/17 12:09 AM
11/16/17 12:09 AM
Mt Morris Michigan
Mt Morris Michigan
See what i can do.
Re: MSD distributor taking timing out [Re: mopar dave] #2404465
11/16/17 01:20 PM
11/16/17 01:20 PM
moparx Offline
moparx  Offline
a touch of blue or red loctite on the screw [after properly cleaning the screw and collar] would ease your mind about things coming loose in operation. just remember if using red [the permanent stuff], a touch of heat will be required to remove the screw. also, my local ACE hardware has those in stock for $1.00 and change. and is only a block from my house vs tractor supply, which is 18mi. away. [i like them both. up] you would be surprised at what ACE carries in auto related items !
beer
Re: MSD distributor taking timing out [Re: mopar dave] #2404469
11/16/17 01:29 PM
11/16/17 01:29 PM
Washington
Washington
See what i can do.
Perfecto.
Re: MSD distributor taking timing out [Re: moparx] #2404471
11/16/17 01:32 PM
11/16/17 01:32 PM
Mt Morris Michigan
Mt Morris Michigan
I have to go to Ace i a bit . see i can find one and maybe add another screw.
Page 2 of 3 1 2 3
