Paint Stripper #2403532
11/14/17 03:43 PM
11/14/17 03:43 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Is there any good paint stripper left on the market now a days? I tried the AirCraft brand that worked in the past, and it didn't work. It is clear now, instead of the yellow it used to be. Has the EPA killed everything?
Re: Paint Stripper [Re: 71birdJ68] #2403577
11/14/17 05:10 PM
11/14/17 05:10 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I buy cans of it from Ace Hardware, but can't recall the name. The can is red and gold.
It works, but takes multiple applications. Also helps if you rough up the top surface with sandpaper or a wire brush first. Sometimes when it's sitting there slowly doing it's thing I will take an exacto knife or a pick and help loosen it up.
The stuff has changed for sure. I can remember using it to remove paint from bmx bike parts when I was a teenager and the paint would start to lift the moment the stripper touched it. Today's stuff is just weaker, or the paint ingredients have changed.
Re: Paint Stripper [Re: 71birdJ68] #2403598
11/14/17 05:44 PM
11/14/17 05:44 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Years back there used to be a brand called Captain Lee's I'd buy at the swap meets. Had lots of Methylene Chloride in it. Nasty stuff for sure but it worked, til the spray bottles they gave you to apply it froze up from the rapid evaporation of the methylene chloride. Chances are the EPA stepped in and severely reduced the usage of that chemical. Along with sanding you might try enhancing your stripper by laying newspaper or plastic over the top of the parts after laying down the stripper, to help keep it from evaporating.
Re: Paint Stripper [Re: 71birdJ68] #2403621
11/14/17 06:50 PM
11/14/17 06:50 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have seen and had good luck using what we called the "bondo buster" DA from Snap on... Some 36 grit and it will go through paint pretty quick.
I watched a bodyman clean up a door jamb with a "finger" cleaner, a type of long fingered wire wheel that made a tough job much simpler..
The fiber disk ( you use on a drill) does a pretty good job also.
I am aware you asked about "chemical" cleaners, but I thought I would give you some options I have seen/used...
Re: Paint Stripper [Re: 71birdJ68] #2403645
11/14/17 07:32 PM
11/14/17 07:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Zip Strip paint remover is still pretty potent
Re: Paint Stripper [Re: 71birdJ68] #2403707
11/14/17 09:31 PM
11/14/17 09:31 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I just used some aircraft and it was still yellow and worked well! You may have gotten an old can see if there is a date on the can.
Re: Paint Stripper [Re: hemirdrnnr] #2403843
11/15/17 03:19 AM
11/15/17 03:19 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I'm using Aircraft Paint Remover now on steel wheels and body panels, and it's plenty strong and working very well. As long as you put it on thick, the paint will craze and lift up in a few minutes. It has a very strong ammonia odor, and it will chemically burn your skin pretty quick if you don't wash it off, so it's potent stuff.
My body and paint shop advised me to use Aircraft and to coat afterwards with Rust Cure or other phosphoric acid and wipe down with mineral spirits to lessen the acid residue.
Re: Paint Stripper [Re: 71birdJ68] #2403918
11/15/17 12:26 PM
11/15/17 12:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I use one sold in the store as a paint stripper for furniture. Brush it on outside because I can see the fumes rolling off it.
Re: Paint Stripper [Re: 71birdJ68] #2403924
11/15/17 12:37 PM
11/15/17 12:37 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Last time I bought some, it took a long long time to work and that was with roughing up the surface. It used to be if you got a tiny drop on you, you'd be running to the hose to wash it off... not you don't even know it's on you. Just another thing they made pretty much useless because of safety concerns.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Paint Stripper [Re: 71birdJ68] #2403982
11/15/17 02:54 PM
11/15/17 02:54 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I am usually one to agree with guys like Silver70.....BUT the reason they banned these chemicals is due to the risk of cancer. Unless you have had some form of cancer, you may not appreciate their efforts.
