Re: MSD distributor taking timing out
[Re: mopar dave]
#2403639
11/14/17 07:19 PM
11/14/17 07:19 PM
Posts: 4,457 Washington
madscientist
Washington
What size is the msd distributor shaft? I think...going by my used up memory...the shaft should measure .485-.490 so a set collar with a 1/2 hole will work. Forgot to mention they usually only have one set screw. I put two more in the collar so I have three. I'm just chicken like that.
[Re: mopar dave]
#2403968
11/15/17 02:20 PM
11/15/17 02:20 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Ill see if i can find a collar that fits snug on the shaft. Thanks I shimmed mine years ago to have .002-.003 up n down movement and added a rubber/nylon bushing instead of the collar and it compresses nicely when the lock down is tightened. I also added a new bronze gear and had Pettis machine the difference off the gear to add a 3-piece torrington bearing deal and the timing is more stable than ever..........The bronze bushing and gear don't seem to play well together and wear quickly.........
[Re: mopar dave]
#2403989
11/15/17 03:05 PM
11/15/17 03:05 PM
madscientist
Washington
Ok thanks Dom. Ill see if i can find something in nylon instead of metal. Dom has a good point about taking the play out of the distributor shaft as well. I always do it, just forgot to mention it. If you do both your timing will be rock steady.
[Re: mopar dave]
#2404072
11/15/17 05:57 PM
11/15/17 05:57 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Go to Tractor Supply and get a 1/2" collar for $1.25...unless you just like paying $20+ for the same part. I've had one in my hemi for probably 5 years now. Fixed the same issue you're having.
[Re: mopar dave]
#2404127
11/15/17 07:13 PM
11/15/17 07:13 PM
an8sec70cuda
IIRC it fit pretty good. Like I said, been in there for around 5 years...no trouble. Must be good.
[Re: mopar dave]
#2404133
11/15/17 07:20 PM
11/15/17 07:20 PM
madscientist
Washington
Does the tsc collar fit the shaft snug? They don't have to fit real tight. Like I said...I'm a chicken so I add two more set screws. I've never had one come loose and I've done probably 40 of them over the years.
[Re: mopar dave]
#2404149
11/15/17 07:47 PM
11/15/17 07:47 PM
madscientist
Washington
Ok. Then ill just go to tsc then. I may already have one. Just have to go thru my nuts and bolts can. Second thought, ill go to tsc. Its quicker. I've spent hours looking for a bolt I could have run to town and bought. Someday I'll organize that stuff better.
[Re: mopar dave]
#2404226
11/15/17 10:02 PM
11/15/17 10:02 PM
Posts: 326 Alberta
Wookie316
Alberta
Anyone have a a reference photo they can post? I am pretty sure I understand but a Photo would be great. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
