Re: Trans tunnel in.. [Re: VernMotor] #240294
03/02/09 09:16 PM
03/02/09 09:16 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Not to pee in your corn flake's but why did you make it that short?
Re: Trans tunnel in.. [Re: dartman366] #240295
03/02/09 09:25 PM
03/02/09 09:25 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
well the only reason you need to take it out is to get to the bellhousing bolts and maybe fool with the shifter linkage...I seen no other reason to make it any bigger..and I did not want to go back past the cross member..being how the foor is welded to it.. I think that would take some strenth of the foor..and I need to add some strenth to the cross member there anyhow..because I need to modified the crossmember on the bottom side a little anyhow.
Re: Trans tunnel in.. [Re: VernMotor] #240296
03/02/09 10:47 PM
03/02/09 10:47 PM
Sac, CA
mopowers Online confused
mopowers  Online Confused
Sac, CA
Man, that looks awesome. One question- with that type of modification, are rocker bars manditory?
Re: Trans tunnel in.. [Re: VernMotor] #240297
03/03/09 02:02 AM
03/03/09 02:02 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
That is sweet! Where can you get those quick release fasteners?
Re: Trans tunnel in.. [Re: mopowers] #240298
03/03/09 11:50 AM
03/03/09 11:50 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I have rocker bars in it..I sure you do ..
Re: Trans tunnel in.. [Re: dave571] #240299
03/03/09 11:51 AM
03/03/09 11:51 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
JEGS LOL ..call hex quick fasteners
