Re: '71 440 HP VAPOR SEPARATOR experts please!
[Re: Furious440]
#2411839
12/01/17 04:14 PM
12/01/17 04:14 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Sorry to Hijack, but I have a related question. I'm running a 440 six pack that does suffer from vapor lock issues. I have an electric blue Holley pump regulated to 6psi.
I was thinking about using the stock fuel line as my return. Since I'm not running a mechanical pump at all, will adding the vapor separator (with .060" hole) help me???
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: gygeneral]
#2412196
12/02/17 12:42 PM
12/02/17 12:42 PM
Posts: 1,674 California
biggE
California
After reading this post I decided to check mine as I've always had issues starting the car after sitting after a period of time. I actually had to put fuel directly into the fuel bowl for it to start. Heres the pic of the return line, full hole, maybe this is my issue. When I disconnected the hose it was full of fuel. There should be zero fuel in the return line. The other issue that I believe is with the fuel separator that you have is that the tube length in the unit is to short. Either way I would replace it.
[Re: biggE]
#2412321
12/02/17 06:13 PM
12/02/17 06:13 PM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
There should be zero fuel in the return line. The other issue that I believe is with the fuel separator that you have is that the tube length in the unit is to short. Either way I would replace it. I ordered a new one from Frank B.. I'm going to open this old one up and look inside when I remove it from the car.
[Re: gygeneral]
#2412736
12/03/17 06:03 PM
12/03/17 06:03 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
After reading this post I decided to check mine as I've always had issues starting the car after sitting after a period of time. I actually had to put fuel directly into the fuel bowl for it to start. Heres the pic of the return line, full hole, maybe this is my issue. When I disconnected the hose it was full of fuel. There were many bogus separators in the marketplace. Besides the return line having no orifice, there was no screen inside and the tubes were the incorrect length!!!! This is one I bought for my 6bbl - junk. Your return tube looks like mine - with no orifice, so I suspect it is a bogus one. Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: Furious440]
#2413527
12/05/17 12:50 PM
12/05/17 12:50 PM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
I’m not an expert but I have my oem one from my Superbird that I have measured and compared to two ones that I have bought. The first was from Year One and had the big (.115 ) hole in the return line. Using a wire with a hook on it, I determined that all three units had the exact same length tubes as my oem. The other unit I bought had the proper size hole as the oem one did. It was not made as clean but it was .060. I’m not sure if it has the screen or not. I bought three of them and just used one on my Charger to replace the new and wrong Year One piece. I’ll see if I can find where I bought these three from. I’ll try and post a picture as well.
[Re: 68jim]
#2413942
12/06/17 12:02 AM
12/06/17 12:02 AM
RealWing
Ontario, Canada
You may find that even the .060" hole can be too big. I discovered on my engine that the larger hole allowed a 2+ psi drop on the fuel pressure measured at the carbs. I soldered the hole closed and drilled it out to .030". My pressure loss was now less than 1 psi and still large enough to pass any vapor and fuel back to the tank. Zero issues even in 95+ degree heat. I agree- 0.060" is too large. I soldered mine and drilled with a 0.040" drill.
[Re: 71birdJ68]
#2414610
12/07/17 11:27 AM
12/07/17 11:27 AM
gygeneral
Ont, Canada
It's there to prevent vapor lock, but also, if you plugged it up, it could cause the fuel pressure to get to high. what about the cars that only have a fuel filter, how do they get away with no return line. I guess it must be vented somewhere then?
[Re: biggE]
#2443699
01/30/18 10:34 PM
01/30/18 10:34 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
After reading this post I decided to check mine as I've always had issues starting the car after sitting after a period of time. I actually had to put fuel directly into the fuel bowl for it to start. Heres the pic of the return line, full hole, maybe this is my issue. When I disconnected the hose it was full of fuel. There should be zero fuel in the return line. The other issue that I believe is with the fuel separator that you have is that the tube length in the unit is to short. Either way I would replace it. I disagree
[Re: sogtx]
#2444455
02/01/18 02:47 AM
02/01/18 02:47 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
After reading this post I decided to check mine as I've always had issues starting the car after sitting after a period of time. I actually had to put fuel directly into the fuel bowl for it to start. Heres the pic of the return line, full hole, maybe this is my issue. When I disconnected the hose it was full of fuel. There should be zero fuel in the return line. The other issue that I believe is with the fuel separator that you have is that the tube length in the unit is to short. Either way I would replace it. I disagree Yeah E that's not right. It's a fuel return line.
[Re: Morty426]
#2444935
02/01/18 11:34 PM
02/01/18 11:34 PM
biggE
California
I disagree [/quote]
Yeah E that's not right. It's a fuel return line. [/quote] It's actually a vapor return line. Fuel can run through the line but if there's fuel in it something is likely wrong like a blocked fuel line or clogged separator.
