Page 2 of 6 1 2 3 4 5 6
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2400996
11/09/17 02:42 PM
11/09/17 02:42 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
So I can fab up a standard oil pressure gauge to check these ? Thanks..
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401035
11/09/17 04:22 PM
11/09/17 04:22 PM
A727Tflite Online content
A727Tflite  Online Content
I would use a gauge with 300 lbs. capacity. Adapt the line to fit the case.
In your situation notonly are you looking for pressure in each gear but how it responds when you lose gears. If it ran for a while after the rebuild you likely have a cut seal or a broken metal seal. Check pressures in each gear and report your findings if you need help deciphering them.
What year trans is this.
Re: Before I pull the transmission out again Question ? [Re: A727Tflite] #2401038
11/09/17 04:28 PM
11/09/17 04:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had my local hydraulic shop make up my line and its long enough to reach in my car because I work by myself. VERY nice tool to have laying around.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Before I pull the transmission out again Question ? [Re: A727Tflite] #2401047
11/09/17 04:52 PM
11/09/17 04:52 PM
Seaford, Va
Seaford, Va
I thank you for the replies . I am at a darn loss here for sure. I will see what I can do about getting a gauge and line to check the pressure. This has been a couple of years of throwing money at the car and still not making many passes..
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401082
11/09/17 06:12 PM
11/09/17 06:12 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Man I know the feeling!I got a 2' high psi hose made and got a cheep gauge to read 250 psi for about 40$
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401083
11/09/17 06:13 PM
11/09/17 06:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some RMVB's won't supply line pressure to the accumulator (middle) test port, in that case you'll have to check the pressure at the front or rear port. Rear in Reverse and front in 3rd.
Re: Before I pull the transmission out again Question ? [Re: John_Kunkel] #2401103
11/09/17 07:05 PM
11/09/17 07:05 PM
Seaford, Va
Seaford, Va
Thanks !!!!
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401434
11/10/17 04:01 PM
11/10/17 04:01 PM
Seaford, Va
Seaford, Va
Okay guys just an update on my junk. I checked the pressure in the front servo in high gear and it was around 145lbs. So I guess the pump is working. I will be pulling the transmission back out and sending my converter to Shawn at Dynamic Converters in De. I hope he finds out what the heck happened. Thanks again for all your help..
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401440
11/10/17 04:13 PM
11/10/17 04:13 PM
PA.
"Little"John
"Little"John
PA.
I hope all goes well. I pulled my transmission 6 times by myself this year on the floor fighting issues so I know how you feel. The good part of the story is I can now do my own transmissions and not have to count on others. I didn't enjoy pulling transmissions 40 years ago and I like it even less now at 61 years old. Good-luck.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Before I pull the transmission out again Question ? [Re: pittsburghracer] #2401470
11/10/17 05:09 PM
11/10/17 05:09 PM
Seaford, Va
Seaford, Va
Brother I know how you feel , 61 here too and feel like a darn turtle on his back trying to get up and down. Cold concrete hurts them joints too.
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401539
11/10/17 07:47 PM
11/10/17 07:47 PM
I would place the gauge on the rear servo port and place the trans in manual low. You said it engages then falls out of gear when you tip out of the throttle. This is when you should be monitoring tha gauge - when it falls out of gear. I doubt you will find anything wrong with the converter based on your opening post.
Assuming you have a rear band apply valve body. You won't know until you try it.
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401636
11/10/17 10:57 PM
11/10/17 10:57 PM
Seaford, Va
Seaford, Va
I don't have a low band apply valve body and the pressure come up on the front servo as soon as I shifted it into high. The wheels won't turning 1st 2nd or 3rd gear. What other ports should I check ??
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401663
11/10/17 11:46 PM
11/10/17 11:46 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
do the wheels turn in reverse?
Without Data, you’re just another guy with an opinion.
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401669
11/10/17 11:55 PM
11/10/17 11:55 PM
Seaford, Va
Seaford, Va
No not unless I really rev it up. That is the only way I can get the wheels to turn at all. Forward or reverse just a little harder in reverse.
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401711
11/11/17 01:19 AM
11/11/17 01:19 AM
I would take it back to your friend and have him pull it down.
Re: Before I pull the transmission out again Question ? [Re: A727Tflite] #2401779
11/11/17 10:07 AM
11/11/17 10:07 AM
Seaford, Va
Seaford, Va
I did and he checked it out again and installed the new valve body for me. He swears it checks out good and has done many many transmissions before
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401795
11/11/17 11:07 AM
11/11/17 11:07 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Does this unit have a roller low reverse drum?
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401799
11/11/17 11:15 AM
11/11/17 11:15 AM
PA.
"Little"John
"Little"John
PA.
Did he air check it after he was done???
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401840
11/11/17 12:27 PM
11/11/17 12:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Could be a missing hard part in the gear train. Don't ask how I know.
Doug
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2401842
11/11/17 12:29 PM
11/11/17 12:29 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
1. no trash in pan
2. fluid not burnt
3. have pressure in high gear at idle
4. only moves when revved up in all gears.
= converter is broken
Joe
