Re: It just died!!!!!!! Update, now runs!!!
[Re: 440Jim]
#240222
03/06/09 12:37 PM
03/06/09 12:37 PM
it would be a good idea to check the phasing of your reluctor vs. the rotor now also, since you changed the reluctor too.
[Re: 440Jim]
#240223
03/06/09 10:20 PM
03/06/09 10:20 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Glad to hear you fixed it.
I just read this post today and was going to suggest checking the resistance of the distributor pickup. Typically they fail open circuit (infinite resistance), but a real high value would be bad also. I didn't have the typical resistance handy, but I could have measured one for you for a reference. But you got a new one and it works.
Good point, I should measure the new one and note that number. The old one was definitely bad, and it failed as you mention, infinite resistance, the multimeter did not even flicker even when you scraped the probes to get a good contact. The circuit was definitely open.
Dan, I will do that phasing check in the morning, thanks for the explanation earlier.
