Re: NHRA Suspends Larry Dixon Indefinitely
[Re: FastmOp]
#2399888
11/07/17 11:46 AM
11/07/17 11:46 AM
Posts: 4,700 Wichita
GY3
Wichita
There are NO chassis cert specifications for a two place Top Fuel dragster. Probably never will be...
[Re: theraif]
#2399906
11/07/17 12:46 PM
11/07/17 12:46 PM
Posts: 4,210 New York
polyspheric
New York
that sticker means absolutely nothing
Everybody signed waivers of everything, or they wouldn't let them in the parking lot.
Boffin Emeritus
[Re: theraif]
#2399970
11/07/17 03:13 PM
11/07/17 03:13 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
An expired sticker? Seriously? I better remove my expired sticker before someone sees it.
[Re: theraif]
#2399997
11/07/17 04:04 PM
11/07/17 04:04 PM
Posts: 11,663 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
For those who believe the sticker means nothing, you're wrong. The sticker is proof of inspection and certification by an NHRA employee confirming it meets specs outlined by SFI. If that chassis were to fail and get someone hurt or killed, where do you think the ambulance chasers are going to go? NHRA doesn't play with the SFI tags on anything. The release form you sign when you go to the track isn't worth the paper it's printed on when the crap hits the fan. Guys who have been caught with bogus stickers and tags on belts, helmets, and other stuff have always been dealt with pretty severely. I've seen cars wrecked and an NHRA guy get to the car before it was cleaned up off the track to pull the sticker off. They take it very serious. Any modifications or repairs from the last inspection are supposed to include a re-inspection. Hell, if you grind on a trans shield to make it fit, the SFI tag becomes void and you're liable to get tossed if they catch it.
That said, this punishment for an expired tag seems to be a bit over the top and I'm sure his involvement with IHRA probably didn't score him any "get out of jail" points. Someone should have scraped the damn sticker off somewhere in the process.
[Re: CMcAllister]
#2400026
11/07/17 05:01 PM
11/07/17 05:01 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
For those who believe the sticker means nothing, you're wrong. The sticker is proof of inspection and certification by an NHRA employee confirming it meets specs outlined by SFI. I'm pretty sure the certification is void if the car is modified after inspection and that the sticker is only meaningful in the world of NHRA. The NHRA lawyers would only have to prove the car doesn't meet any specs listed in the rulebook.
[Re: CMcAllister]
#2400056
11/07/17 05:43 PM
11/07/17 05:43 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
When I wrecked in 2010 a track official and an NHRA inspector came right to my Trailer. (Norwalk) He explained the rules and said they could either pull the sticker or the inspector could check out the damage and possibly let it slide. I opened my trailer doors and said go at it. He climbed around and in the car and said the chassis was fine. I thanked him and they left. The strap on my helmet was cut off before the car left the track by an official
[Re: @#$%&*!]
#2400075
11/07/17 06:36 PM
11/07/17 06:36 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
For those who believe the sticker means nothing, you're wrong. The sticker is proof of inspection and certification by an NHRA employee confirming it meets specs outlined by SFI. I'm pretty sure the certification is void if the car is modified after inspection and that the sticker is only meaningful in the world of NHRA. The NHRA lawyers would only have to prove the car doesn't meet any specs listed in the rulebook. Ambulance chaser: "Well Mr. NHRA representative, if it doesn't meet specs, why is your sticker on there saying that you certified that it does? Can you prove that it was altered after your agent certified it? Shouldn't you have reasonably anticipated that modifications may be made in the normal course of the use of that chassis and adjusted your certification process accordingly?" Stupid people managed to sue GM and win because they had 5 pounds of junk on their key ring and it would rotate the ignition switch and shut the car off while driving. Juries rule in favor of idiots who cause their own problems everyday. The sticker makes NHRA liable for confirming the chassis meets specifications. Why would they haphazardly be OK with leaving themselves open to the whims of a jury who know nothing about any of it? They take all of it seriously and are quite proactive about it.
[Re: theraif]
#2400131
11/07/17 08:18 PM
11/07/17 08:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
As I understand it, NHRA was concerned that LD was booking rides in the car at SEMA and that the presence of a tag could lead potential customers to assume that the car was in fact certified in that configuration. Liability issue. Had it been scraped off, I don't think there would have been this problem.
I see no reason that LD can't continue to run this car and take folks for rides, as long as he does it at IHRA or outlaw tracks. NHRA can't stop that. They can only prevent him from participating at their events with his legal car.
