What happened to the 550hp 470? That seemed like a sweet combo for that car
That was a very good engine and maybe I should've kept it. But you only learn by trying new stuff. I sold the 470 (actually was a 466) to a Moparts member several years back. I then made the classic mistake of getting too fancy with my next engine. The low deck 512 has cross bolted mains, roller cam bearings, 440 size main journals, etc. It has a Callies crank, Crower rods, etc. Way, way overbuilt for what I need.
I will most likely pull the 512 out in the near future and sell it and build something much simpler for the car. I have a 426W block that I can use. It won't be "numbers matching" but it will be closer to original than a low deck block since the car was a factory 426W car.
I'm also going to put EFI on the car and then I think I'll call it good. Well, maybe get rid of the Doug Nash 5 speed since it is a really clunky transmission and buy something modern like a T56!
